Amp for 4 tuba 60's?
pyroibw
#1 Post by pyroibw »
whats a good amp to use for 4 lab15 loaded tuba60's?
was going to use a xti4000 but that leaves no headroom. any suggestions?
Built: 8 T60's
Soon: * OT12's
sine143
Re: Amp for 4 tuba 60's?
#2 Post by sine143 »
XTI 4000 is more than sufficient? 2 on each channel, prolly net you around 1100 watts on each channel (550 per driver... which is probably over the voltage limit).
sine143
#3 Post by sine143 »
oopsie, 6 ohm drivers, so you get more power form the amp I'm not the mathematician I'd like to be.
What is the voltage limit on the T60 loaded with the lab 15?
