Page 1 of 2
Crown XLS Drivecore Amps...anyone used 'em yet?
Posted: Tue Jun 15, 2010 10:59 pm
I'm about to pull the trigger on an XLS 1000 (bridged for subs) and an XLS 1500 (OTops with 2512s on one side, monitors on the other)
Anybody tried 'em out yet?
Re: Crown XLS Drivecore Amps...anyone used 'em yet?
Posted: Wed Jun 16, 2010 12:33 am
by wallywally
Check with Leland (forum member and authorized builder) @ www.speakerhardware.com . He sells them and I believe he has demoed them.
Posted: Wed Jun 16, 2010 6:18 am
by LelandCrooks
I haven't run them yet, I have looked them over pretty good. Drop me a line. I'll even preset the amplifiers for whatever bfm cabs you're running.
You must voltage limit them with your system. The can only have 1 filter per channel, either hp or lp. I can't do that ahead of time. I can preset everything else.
Posted: Fri Jun 18, 2010 11:18 am
by saloonstudios
I got a XLS1000 to power my THTLP, but I've only run it for 10 minutes to test 30hz sine waves. The fan never kicked on but I was only outputting 13 volts. It's very small, shorter and lighter than home theater receivers. It almost feels like a toy, but it seems to be just what I needed for a HT sub amp.
Oh and yeah there's an internal crossover, but I'm going to bypass that and use my CX3400 so I can HP and LP-
Posted: Fri Jun 18, 2010 12:02 pm
Well, I placed my order to buy the XLS1000 to run subs (bridged) and the XLS1500 to run Otops off one side and monitors off the other.
It will be replacing 2- QSC GX5s and an old Behringer. Trading about 110 pounds for 17....rack just got a little lighter!
Posted: Fri Jun 25, 2010 11:00 am
by Ken Lustgarten
The savings in weight with these amps is great. Setting and and tearing down will be much easier. I am very curious to see how well they preform with subs. I am old school, light weight and the ability to drive subs were contradictory. On the other hand these new light weight amps opened up a great opportunity for me to get started with some of my own gear. I just bought 2 XLS amps, a 402 and a 602 for $425 total :hyper: If you search you can find awesome deals on the older XLS line. In the future if things go well I will look into lighter amps.
Posted: Fri Jun 25, 2010 1:28 pm
by sine143
I feel like these will be decent home theater amps. Its not like anyone listens to HT at WAR VOLUME, so limiting shouldnt be an issue, and you dont *need* to hp the THT as long as you eq 22hz (max excursion point) down as far as you can with a high Q.... I think?
Posted: Fri Jun 25, 2010 1:54 pm
I sure hope that they are more than HT amps. I'm planning to run T39s and OT12s with them.
Why would they be any less appropriate for live sound than the Peavey IPRs? They are a lightweight amp also. Or, even the XTIs?
Posted: Fri Jun 25, 2010 2:03 pm
by sine143
only 1 filter per channel, less EQ than XTI, no limiting.
I've heard sketch things about the IPRS... but I cant actually back it up.
Posted: Tue Jun 29, 2010 1:57 am
by Charles Warwick
Does anyone know what the Peakx limiters in the new XLS series do? :confused: Do they actually limit voltage to the speaker, or are they just a psuedo-limiter?
Posted: Tue Jun 29, 2010 6:27 am
by Ron K
Charles Warwick wrote:Does anyone know what the Peakx limiters in the new XLS series do? :confused: Do they actually limit voltage to the speaker, or are they just a psuedo-limiter?
PROBABLY A GOOD question for the Crown forums.I'm sure one of their techs would chime in.
Posted: Thu Jul 01, 2010 1:55 am
by saloonstudios
As far as being a good HT sub amp, they are quite adequate. I've run mine for hours and I still haven't heard the fan turn on. I don't have any of the internal DSP's operating though-
Posted: Fri Jul 02, 2010 6:40 am
by Israel
they seem 2B better for tops than subs and for DJs better than for live sound an xti will do better on subs cause of the filtering and limiting capabilities
Posted: Fri Jul 02, 2010 8:07 am
Israel wrote:they seem 2B better for tops than subs and for DJs better than for live sound an xti will do better on subs cause of the filtering and limiting capabilities
I'm only interested in the power amp capabilities - not the DSP, as I already have those covered. So, other than DSP is there any reason why you think they wouldn't be good for live sound?
Posted: Fri Jul 02, 2010 12:04 pm
by LelandCrooks
Bruce Weldy wrote:I'm only interested in the power amp capabilities - not the DSP, as I already have those covered. So, other than DSP is there any reason why you think they wouldn't be good for live sound?
Nope.
I've been putting together kits with XLS for tops and XTI for subs.
