Crown XLS 202
GekoMusic94
Crown XLS 202
Hi,
Can I use a crown XLS 202 for 2 Titan 39 Delta 12lf loaded?
Have:
2x FBT Jolly8ra (active)speakers (100-20.000Hz)
1x Voice System SUB VS8 (active)subwoofer (55-100Hz)
1x MTH-30 (RCF LF12G301)
Re: Crown XLS 202
What voltage limit for D12lf in T39?
Re: Crown XLS 202
It will be very close to the displacement limit of the deltas, it will work (is a crown) but youll be better with the 402
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
MADE
4- OT12'S BETAII
GekoMusic94
Re: Crown XLS 202
Thanks,Gregory East wrote:What voltage limit for D12lf in T39?
The displacement limit is 35V (150 Watts)
Have:
Re: Crown XLS 202
delta 12lf has a vd of 243 i think is more on the 200w disp limit correct me if wrong
MADE
4- OT12'S BETAII
MADE
4- OT12'S BETAII
GekoMusic94
Re: Crown XLS 202
No...Israel wrote:delta 12lf has a vd of 243 i think is more on the 200w disp limit correct me if wrong
Have:
Re: Crown XLS 202
uupppsss it is in the bottom part!!!!!! then i suggest you to go with the beta12a II same displacement, more sensitivity, cheaper, if you move up to the 3012s later (which i recommend) you can use the betas for some ot12s..... about the amp you can move one in each ch or both in one channel
MADE
4- OT12'S BETAII
MADE
4- OT12'S BETAII
GekoMusic94
Re: Crown XLS 202
Ok... But now i'm considering the BP 102... I can build a 13'' wide cab that's very confortable for me to transport.
What do you think about the BP 102?
Have:
Re: Crown XLS 202
what i think about each speaker that can be used in the t39 is that they are drivers the sound is the cab itself i made mine from the beggining with 3012s two of them can cope with 4 ot12s with my second pair i test the beta 12s from my ots on the titans you can match the sound of both until the betas reach their limits then the 3012s can keep on and on for more you can hear the diffrence in chest pounding presure...... the bones here is that with any 150w limited driver you must hear almost the same great sound.. i havent tested the bp102 on mines but they got to sound great to be recommended by Bill on the plans ...do you already have a pair with bp 102?? with 4 of them u can get a big rumble with a crown 202
MADE
4- OT12'S BETAII
MADE
4- OT12'S BETAII
GekoMusic94
Re: Crown XLS 202
No i haven't yet but i'm planning to build a pair...
Have:
Re: Crown XLS 202
for what you will use the titans?
MADE
4- OT12'S BETAII
MADE
4- OT12'S BETAII
GekoMusic94
Re: Crown XLS 202
For small bands in medium size pubs...
Have:
Re: Crown XLS 202
what i can say about any speaker reccomended as adecuate for a t39 is that they are drivers the sound is "produced" by the horn itself. any of us t39 owners here agree that with any driver t39s are far better than a 15 sub in sound in a watt per watt basis but todays subs are designed to withstand a lot of pressure (watts) this will make em reach a titan that just can take 150watts even on means of higher distortion and compression
what to do to take the better out of a titan
1 make em as wide as you can.. wider = better low end response
2 single driver cab s are better as you gain by vcouple two of them
3 this is some heard experience.. if you use a ten and you are good with tools make the cab as for a 12"then retrofit it for a 10" this way you can add a 12" later (maybe a 3012lf if you can later on, i recommend the better driver for bass horns allways ) and ***PLEASE*** ask how to do it first ( I havent so i cant tell you)
4 allways follow rules of placement this actually makes a huge diffrence
MADE
4- OT12'S BETAII
MADE
4- OT12'S BETAII
