What I need to set them to is another thing.
For the subs and mains cause they are on different channels, should I switch the subs low cut off at 50hz or 30hz?
anyone have the same model and use this feature?
The clip limiters are just that, they keep the amp from clipping, and they don't sound totally nasty, but they're harmless. The HP filters are probably made moot by your properly configured crossover, but again, they're harmless.Scott Brochu wrote:On the back I am noticing the limiters and all the switches.
What I need to set them to is another thing.![]()
I turned off the clip limiter and turned on the 30Hz HPF when powering my Tuba 24's. But I also have a HPF of around 37Hz on my crossover w/ 24dB slope.Scott Brochu wrote:On the back I am noticing the limiters and all the switches.
