Recently I've switched the piezos off, while keeping some treble on the bass, and I think it sounds better in a band context, at least on the parts with a bit of energy/or enthusiasm.
On the other hand, I also kind of like having the piezos sometimes when the MetalZone is on
So I'm slowly coming to the conclusion that I need to be able to switch the piezos on and off, sometimes in the middle of a song. Hence the idea of a footswitch.
Maybe I could also isolate the frequency spot that bothers me and EQ it out. Not sure my EQs would allow fine notching like that though...
Here's my question:
Can I "hotswitch" the piezos without damage to the amp (Solid State from the 80s) and to the piezos?. When I turn them off, I usually turn the master down to 0 during the operation. That's probably not needed though.
What's the best way to do it if someone already has experience with that?
Thanks!
