flying safer than ground stacking?
RubiconProSound
Location: Pollock Pines CA. (between Lake Tahoe and Sacramento...)
#1 Post by RubiconProSound »
I found this little blurb from the Nexo site...it has a few little tidbits I never thought about regarding ground stacking.
Ground Stacking Safety
Statistically, many more injuries occur due to unstable ground stacked PA systems than those associated with flown systems. There are several reasons for this fact, however the message is clear:
• Always survey the supporting structure upon which a ground stack is to be built. Always
look beneath PA wings to inspect the deck support and if necessary ask for the stage
scrims and dressings be removed to allow access.
• If the stage surface slopes, as it does in some theatres, ensure that the system is prevented
from sliding forwards due to vibration. This may require the fitting of timber battens to the
stage floor.
• For outdoor systems ensure that that the system is protected from wind forces which might
cause the ground stack to become unstable. Wind forces can be huge, especially upon
large systems, and should never be underestimated. Observe meteorological forecasts,
calculate the “worst case” effect upon the system prior to erection and ensure that the
system is secured appropriately.
• Take care when stacking cabinets. Always employ safe lifting procedures and never attempt
to build stacks without sufficient personnel and equipment.
• Never allow anyone, whether operators, artists or members of the public to climb onto a
ground stacked PA system. Anyone who needs to climb over 2m high should be fitted with
suitable safely equipment including a clip-on harness. Please refer to local Health and
Safety legislation in your territory. Your dealer can help with advice on access to this
information.
• Apply the same attention to all safety matters when de-stacking systems.
• Be aware that safety procedures are as important in the truck and in the warehouse as they
are at the venue.
Built so far:
Re: flying safer than ground stacking?
I can believe that. Someone ground stacking is as likely as not to make the pile too high with inadequate tie downs, if any. It's tough to fly unless the venue is set up for it, and chances are better that it's not a jury rigged affair.
Dazombiewoof
#3 Post by Dazombiewoof »
Major touring acts who are flying the PA get such a discount on their tour insurance they always want one or more certified bonded riggers. I did see a flown cab take a dive to a stage once. Guy on the ground it came close to probably went home shortly thereafter, if only to change underwear. I was a very good distance away and fortuneately maintained control. Made an impression, literally and figuratively.
"Telling you all the zombie truth, here I'm is....."
wr_anders
#4 Post by wr_anders »
Even with small stacks, I've used ratchet straps. Just always made sense.
Even when the stacks got their highest, about 12 feet, we used ratchet straps and nylon cargo nets staked deep and wide.
Good way to keep people off the speakers too. :)
LET THE BASS CANNON KICK IT
Amps this big are basically arc welders with an input.:lol:
   Done
Dual-15" THT
Dual-10" Auto Tuba
Dual-8" T18
Straight SLAs x2
ben.in.salzburg
#5 Post by ben.in.salzburg »
To what do you attach the ratchet straps when indoors or on concrete?
wr_anders
#6 Post by wr_anders »
ben.in.salzburg wrote:To what do you attach the ratchet straps when indoors or on concrete?
I always laid the straps on the ground, set the stack on top, then looped the end over, attached it to itself and cranked down.
   Done
Dual-15" THT
Dual-10" Auto Tuba
Dual-8" T18
Straight SLAs x2
SoundInMotionDJ
#7 Post by SoundInMotionDJ »
Indoors, I will only "ground stack" with the "ground" is a riser or stage. There is always plenty of places to attach straps on a riser. I have even driven screws into the decking of a riser to get a good place to attach a strap.
In a pinch, I have stacked on a banquet table that is flat on the ground (legs are still folded). That provided some outriggers for the stack.
With my last outdoor gig with a stack, I had the ability to strap to the support legs of a gazebo.
--Stan Graves
10 T39S + 10 DR200 + 1 T48
