I would like to push the level up a bit on my subs. I am lighting the limiter occasionally on my tops, but never on my T39s. I feel like I could use to push them a bit more to bring up the overall level of the subs and even out the sound.
My T39s are 3012lf loaded, powered by an Crown xti2000.
Can I bump up the output gain setting on the sub's output channel coming from the DCX or am I better off changing the EQ in the DEQ?
Is that DCX output gain before the limiter?
DCX Question
- jswingchun
DCX Question
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
- David Carter
Re: DCX Question
Yes, you can do it on the DCX.
Dave
- 2 x Titan 39 (BP102 - 14"W)
- jswingchun
Re: DCX Question
cool, thanks!David Carter wrote:Yes, you can do it on the DCX.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
- Scott Brochu
Re: DCX Question
I do not know how to set the limiters on mine anyone anyone???Really just the numbers on that page/screen is confusing.
I set my gain for the subs 39's Delta12lf's at 3 db's. What about you?
And what do you cross your at?
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: DCX Question
Scott Brochu wrote:I do not know how to set the limiters on mine anyone anyone???Really just the numbers on that page/screen is confusing.
?tahw
Turntablist
Re: DCX Question
Here you have it on setting limiters:
http://billfitzmaurice.info/forum/viewt ... =14&t=8755
-2 T48 3015LF
-2 DR250 2510 crossfired
