BC Pine Plywood
BC Pine Plywood
I'm in the process of building a Titan 48 (24.5") out of 1/2" BC pine plywood. If I get it together with no air leaks, what are the drawbacks other than the extra weight and the not-so-smooth outside?
Re: BC Pine Plywood
None.brodave2 wrote:I'm in the process of building a Titan 48 (24.5") out of 1/2" BC pine plywood. If I get it together with no air leaks, what are the drawbacks other than the extra weight and the not-so-smooth outside?
