New THT Build!
67baja
Re: New THT Build!
#91 Post by 67baja »
Looking great. Hopefully you can hear them soon.
escapemcp
Re: New THT Build!
#92 Post by escapemcp »
If he turns them up, hopefully we'll all be able to hear them :lol:
Bryson
Re: New THT Build!
#93 Post by Bryson »
Oh yes, this thing does make bass.... I keep forgetting! :D I'm going to run out of duratex. I think i'm going to move it to the basement anyway though and fire it up. Enough of the waiting...
Done: 2 x Dual Loaded T24 (BP102), 2 x 16in T24s (BP102), THT
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#94 Post by Bryson »
By some miracle, I had enough Duratex to finish! Even some left over. It goes a long way if you primer first. Remember that. Ok, here it is, final side drying!!! It's going to the basement tonight!
Now: T18...
Next: ???
Rowan611
Re: New THT Build!
#95 Post by Rowan611 »
Looks great. I was going to go with a black satin to match my KLFs, but now I'm thinking I might go with the Duratex.
1299s L/C/R | Volt8s | Crown amps | 24" THT x 4| Minidsp 10x10 2x4HD | Panamax 5300PM | LG 65B6 | Oppo 203 | Crowsons | HoverBoss | Behringer NX amps
THT Build
Hackomatic
Re: New THT Build!
#96 Post by Hackomatic »
'tis truly ashame that something so well built and nice looking will be relegated to a dark corner in a basement . . .
Here's to you, THT! We loved ye, but we hardly knew ye . . .
Dave H
ripNdeb
Re: New THT Build!
#97 Post by ripNdeb »
Bryson wrote:By some miracle, I had enough Duratex to finish! Even some left over. It goes a long way if you primer first. Remember that. Ok, here it is, final side drying!!! It's going to the basement tonight!
Duratex is so awesome. I did everything in my sig with ONE gallon except the 20" titans and one side of the WH10
Bryson
Re: New THT Build!
#98 Post by Bryson »
Well, i've had it for a few days now. After battling a ground loop hum, I've got it silent. It sounds great. Effortless deep bass. I've taken it nowhere near max volume. The house shakes when this thing is playing low bass. It sounds great with anything I throw at it. My basement configuration is a little weird so placement has been tough. But it's working. Just sounds better everywhere the couch is not... ha! Anyway, it's great. Thanks Bill for the design.
Here is the finished THT:
Now: T18...
Next: ???
Re: New THT Build!
#99 Post by Grant Bunter »
If it appears to be lacking in the listening position, ie the couch, try the subwoofer crawl.
Put your sub on the couch, play stuff through it.
Crawl around the room until you find point(s) of good bass response. Wherever the bass sounds strongest, is where you then place your sub. Hopefully one location also works for WAF factor...
Re: New THT Build!
#100 Post by Tom Smit »
+1
