lincsoldbird wrote:Good build but that ply is nasty, I would get birch next time. It may cost more but it very little in the great effort put in to building these cabs.
Yeah, I searched for it and thought I had it - it was a busy shop and the bloke just wanted to get me out the way, so I didn't check it thoroughly
  I think I have found somewhere that sells the proper stuff
  Will use it on the next one, and this can be my test speaker!
Anyway, todays update:
Got a sample handle and speakon jack dish+speakons through today.  I am planning to mod both the handle and the speakon dish to fit, as they won't quite squeeze in the 'unpressurised' sections at the top and bottom on the back of the cab.  The Handles are having the back bit removed, and the 45degree bit of wood (reflector - I think) on the top back will create the 'dish' of the handle.  After a few rough cuts, the handle looks something like this:
The cut is only rough at the moment, I am yet to do the 'neat' cut to the line I have drawn.  The handle 'dish' is only plastic, so easy to cut.
The speakon dish has to be modified in a similar way.  I did a test cut tonight to see if I could get the saw to bite on the angled surfaces, and got success (bottom right of dish) - the pencil line is the 'ish' cut line so that you can picture what I am up to.
Will do the angled cut when I know the exact size to cut it to.  Again the bottom reflector will provide some of the 'dish' when it's installed (face down when speaker upright).
Do you think that the spades on the back of a speakon plug would take a bend?  With the speakon dish having to be positioned very near to the back of the cab with the speakon plugs pointing to the back of the cab when plugged into the socket, I need to pinch every inch that I can to squeeze it all in.  Bending the speakon spades (the ones attached to the speakon socket, NOT the faston connectors) would solve this space issue.  I suppose only way to find out is to try trashing the plug in the pic.  I think the screw connectors will be too long, but I got both to test
I still hadn't worked out how to test for leaks, but is weatherproof seal-ing all edges and then screwing the side on going to work?  At the moment, I think this is the best way i can work out... I dunno how the rubber tube system that Bill mentions is supposed to work - How do you get it round to panel 5?
Also I have decided on the bottom back edge after about a week of pondering.  I didn't want a straight edge, cause it would get easily dinked, so was looking at a wheel/castor with a 30mm radius bend to go from upright to level (does that make sense).  This 30mm rounding would have caused untold problems squeezing the speakon dish in.  Today I sussed the solution.  A straight edge (no rounding off) BUT with 4 wheels.  That way, the wheels *should* take the dinks and not the fragile back edge.  This way allows me maximum space to fit in the speakon dish underneath.  Most other edges will have a 10mm rounding on them, to match the corners and the handle.
Phew... I think I now know what I am doing and how all these 'accessories' will fit in.  It only took me a week of thinking (mostly in work time though!
 ), but I got there!
