OT12 and T48 combination
88h88
Re: OT12 and T48 combination
#91 Post by 88h88 »
He's got photos of the rack on facebook and it's genuinely hilarious how tiny it is to run all that kit. :lol:
#92 Post by Tom Smit »
Kudos, Pulseman.
Thanks for sharing, Lostenigma!
leamy_f
#93 Post by leamy_f »
PulseMan wrote:
Boyd wrote:'m curious about your design considerations for choosing the SLA-Pro as centre fill, compared to say, another Otop12 melded?
How does the SLA-Pro compare tonally to the Otop 12, and do you find you need to EQ it differently?
Hi Boyd
Thanks for the kind words :wink: .
Regarding your centre fill question, most people would recommend the OT12. I tried both and due to most of the shows I do, the crowds stand right up against the stage ramps and with the T48's under the stage, I found the SLA-Pro worked better (overall the system felt fuller and tighter to my ears being that close up to the cabs). When I built the SLA I added an extra section to the back of the box and added a plate amp to it, it has a HPF of 100hz built in too. I run it off a separate output on my DCX crossover and also through one of my DEQ's to fine tune the EQ a bit. Strangely enough the SLA's RTA EQ is pretty flat but when I tried the OT12 as centre fill it's RTA graph was all over the place.
PulseMan
hi there pulseman is there any chance you could post a photo of your deq settings for your main stacks and also what procedure you use for setting eq at your various gigs....regards..Frank leamy
PulseMan
#94 Post by PulseMan »
Hi all
Three years now that I'm using this BFM setup and all is still "Super Duper". :hyper: :hyper:
Every year I keep getting the same contracts over and over and more. :cowboy:
Anybody still indecisive about building a BFM rig, DO IT you won't be sorry.
Once again thanks to Bill for his designs and to all the forum members who have contributed with advice and +1's over the years.
God Bless
Jose
BUILT
8 T48's 24" 3015LF LOADED
2 WEDGEHORN 10 MKIV's
1 SLA PRO FOR CENTRE FILL
Like us on facebook
https://www.facebook.com/Pulse.Entertainment.SA‎
cave
#95 Post by cave »
Hi guys, I am currently building a rig just like Pulseman's and I must say I'm really encouraged. I had to suspend building 8 DR250s which I'll continue after finishing the OTops 12 jarrays. Thanks Pulseman you are a worthy ambassador.
Built 2 x DR 250
Building 8 DR 250
Built 8 x OTOP 12 JARRAY
Built 2 TITAN 48
Lostenigma
#96 Post by Lostenigma »
Hey PulseMan
Long time, you've been quiet lately, hows things going with you and your setup?
Really miss your posts and pictures, as BFM rigs are almost non existent here in Portugal and Spain areas :cry: .
I really look for inspiration from you as I have a similar combination as you just less cabs :mrgreen:
Regards
LostEnigma
2 OT12's
2 T48's
PulseMan
#97 Post by PulseMan »
Hi all
Just finished another successful tour of festivals here in South Africa.
BFM rig performed flawlessly as usual. :cowboy:
Regards
PulseMan
BUILT
Like us on facebook
ripNdeb
#98 Post by ripNdeb »
88h88 wrote:He's got photos of the rack on facebook and it's genuinely hilarious how tiny it is to run all that kit. :lol:
Who cares about the kit? We want closeups :)
#99 Post by Chris_Allen »
Good job PulseMan.
I think you've had enough fun, it's time to make your rig bigger!
PulseMan
#100 Post by PulseMan »
Chris_Allen wrote:Good job PulseMan.
LOL, don't want to steal the big company's work away from them, do we now? :D :D :D
PulseMan
BUILT
Like us on facebook
allroundFX
#101 Post by allroundFX »
Do you still use the Synq amps?
Cause we had some trouble with them resulting in 6 blown drivers before we figured out it was the synq. It was hard to find cause the drivers blown all on the last hourof a gig of 10 or 16 hours. But during the last one I was monitoring the outputs with my engineer and all of a sudden without any indication or reason it went into clip and protection and blammo Silence from the subs. it was a real big WTF? moment. Never touched them again, and no more blown sub drivers.
Famous BFM quotes: "Zobels are for those who don't know how to design crossovers"
PulseMan
#102 Post by PulseMan »
allroundFX wrote:Do you still use the Synq amps?
Hi sorry for late reply, pretty busy at the moment.
Anyway, yes still use them and no issues thus far.
I know the very first batch of 3K6's had a module issue which they did rectify some time back.
Touch wood mine are stable and have worked pretty hard.
BUILT
Like us on facebook
Middelkevin
#103 Post by Middelkevin »
A question about your synq amps.
Normaly the 'clip' led will light when the amp is clipping, only that is not the case with these amps is it?
If I run some subs on my 2k2 amp at a certain volume the clip led will light, only not the clip limiter light.
So the amp isn't clipping am I correct?
Do these clip lights light up when you're pushing them?
Build:
2x Jack 15 3015/ASD1001
2x Titan 48 3015LF 36''
Building:
4x Wedgehorn 8
8x Otop J-array cabs
escapemcp
#104 Post by escapemcp »
It should be the DCX that is clipping (well, limiting) the signal, not the amps. The amps should never clip (unless the amps are underpowered (or running off a weak power supply)).
