SLA Pro
bzb
Re: SLA Pro - almost done, annoying hiss/hum
#91 Post by bzb »
Bill Fitzmaurice wrote:Tweeters don't hiss. Amps hiss.
Doh. Is that mainly an issue with the XTi series? Strangely enough, I get a light hiss when I hook up the OT12s, but it's not nearly as prevalent as the SLA. I would have guessed the OT12s would make that sound louder.
I can forsee the hiss, being as loud as it is, being an issue at really quiet ceremonies.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
bzb
#92 Post by bzb »
SeisTres wrote:All I can say is....
you forgot to paint the big black round things :noob:
Crap, you're right. Don't worry, I'll paint them after I caulk them.
Bobby Shively
#93 Post by Radian »
What else did you have upstream of the amp? anything?
Cabs looks frigg'n hot BTY. :D :clap: Nice work!
bzb
#94 Post by bzb »
Radian wrote:What else did you have upstream of the amp? anything?
Thanks, I wasn't 100% sure I made the right decision until that 5th coat of Duratex :lol: Then I thought, Bill hasn't steered me wrong. And I want that extra work from the planners/coordinators, so these damn things are going to be white!
I don't have any faders up on the board. I could try out the 01V tomorrow see if it makes a difference. Typically I have the board feeding into ART 341 EQ, but it's in the other rack right now.
Yamaha 124 -> Crown XTi 2000 with xover set @100Hz 24db Butterworth -> banana to speakon
Bobby Shively
#95 Post by Bill Fitzmaurice »
Tweeter sensitivity can be reduced by placing the 4 ohm resistor before the capacitor rather than after. But I doubt the hiss would be noticeable other than in a small quiet room.
#96 Post by Chris_Allen »
bzb wrote:Doh. Is that mainly an issue with the XTi series?
My XTi4000's (both of them) make my DR200's and O10.5 hiss, but the Behringer, Yamaha and Peavey amps don't.
#97 Post by Bill Fitzmaurice »
Chances are the DSP is the source of the noise. But possibly no worse than the noise that results from an external DSP. Still it would be prudent to make sure the DSP gain structure is properly configured.
bzb
#98 Post by bzb »
That's exactly culprit. I set it to DSP Off and the "airy" sound changed the more familiar white noise hiss, but much lower. Only setting I had on that profile was the crossover and limiter. I guess I'll be playing with System Architect to see if I can get that removed.
Thanks for the ideas. The cabs sound fantastic, Bill. I'm tempted to build two more black ones.
Bobby Shively
Re: SLA Pro
#99 Post by Gregory East »
What about black road cases with tophats for these princesses so they stay white :mrgreen:
johns811
Re: SLA Pro
#100 Post by johns811 »
Couple questions. Did you have to cut individual tweeters to get them to look like that. They look like 1 unit. Was it difficult to do that. How do the middle tweets stay in the box with just the screws on top and bottom.
To paint the tweeters, does anything need masked to not ruin them.
Lastly is there a less expensive woofer choice like Dayton, or Goldwood that would perform decent.
Any info appreciated.
Frederic Gelinas
Re: SLA Pro
#101 Post by Frederic Gelinas »
johns811 wrote:Couple questions. Did you have to cut individual tweeters to get them to look like that. They look like 1 unit. Was it difficult to do that.
It's in the plan. The plan shows how to cut and glue the tweeters. To paint them, use a can of plastic paint.
Frédéric Gélinas, HF Audio
HFAudio.ca
Free tone Generator
David Carter
Re: SLA Pro
#102 Post by David Carter »
Very nice!
What would be your estimate of total build cost per cab?
Dave
- 2 x Titan 39 (BP102 - 14"W)
bzb
Re: SLA Pro
#103 Post by bzb »
johns811 wrote:Couple questions. Did you have to cut individual tweeters to get them to look like that. They look like 1 unit. Was it difficult to do that. How do the middle tweets stay in the box with just the screws on top and bottom.
As above, it's in the plans. It's not difficult, they're just plastic. The ABS cement that Leland has in black works perfectly. They're attached by caulk and clamps.
If you go back a few posts, there's a picture of the clamps on the piezos. I actually was able to get those blue Irwin clamps almost centered on them, and that provided enough pressure to get a good seal when the caulk dried.
I disassembled the piezos before cutting, assembling, and spray painting them with a semi gloss white.
The drivers are pro drivers, since these are pro cabs.
David Carter wrote:Very nice!
Even better for ya, I kept an Excel chart this time.
Code: Select all
Plywood	1	30.74	30.74
Alpha 6	8	35.99	287.92
Piezo 1016	12	2	24
Shipping	1	20.54	20.54
Top Hats	2	5.95	11.9
Xover Filter	2	7.99	15.98
Damping	1	5	5
Speakon	2	3.75	7.5
Duratex	1	70	70
Grills	2	24	48
Grill mounts	1	7.5	7.5
			529.08
$265 each not including the fasteners and way less than a tube of PL. I also didn't include the speaker foam, but I don't think it costs much. I have a friend who does pro installs on boats that's going to give me some cutoffs.
Bobby Shively
Re: SLA Pro
#104 Post by Bill Fitzmaurice »
bzb wrote:
$265 each.
I had to make a best guess as to the retail value of these, because there's absolutely no commercial equivalent. I settled on $599 based on what is out there, and they're primarily one-way systems loaded with three or four inch drivers that don't come close to what the SLA Pro offers.
I'd drill holes through the array frame for a few more screws.
bzb
Re: SLA Pro
#105 Post by bzb »
bzb wrote:
$265 each.
I'm going to compare them to the EV ZX1-90s as best I can on video. They absolutely kill them in terms on sensitivity (of course) and the single SLA is easily is louder than the two ZX1s. Considering the ZX1-90s are $299 at the cheapest, the SLA Pro is an incredible value.
What do you think of something comparable to the size of the ZX1s, along the lines of 4-5 piezos and 2 of the Alpha6C?
I was kind of surprised to find that the caulk is holding pretty well, but I'll add some more screws. Any ideas on re-caulking the outside portion (between the piezo frames and the ply)? My finger won't fit in there to smooth the caulk.
Bobby Shively
