That is nice, your business is extending beyond DIY hardware, congrats
Do you happen to know if the upcoming Drivecore amps will run on anything between 100V-240V and 50/60 Hz just like the XTi range? Looks like all of these exciting new affordable lightweight amps take their time arriving in European stores, so it might make sense getting one shipped from the US if it would run on local voltage.
Pretty sure they will. I have specs somewhere from Namm, I'll see if I can find them.
Lots of big things coming pretty soon, to make it all easier. I'm slowly putting the pieces of the puzzle together.
Oh Snap.... wow. that gives me something to think about.
I was eying your kits that were coupled with the xti's, but this is interesting as well
Side note:
you wouldn't mind sharing your settings for the xtis would you? If not, I understand, cause that's a definite point of attraction for the new guys looking to get into a plug and play situation.
Although I cannot find mention of it, there could be a default HP filter. But if so it would probably be set lower than most would need for pro sub operation. If not some purists probably find a reason to bash Crown for building an amp that "does not perform" at subsonic frequencies.
I need to move some drivers. Almost all the guitar stuff on the site is on sale. If you use something besides bfm cabs and need some drivers drop me a line. Bargains to be had, especially on Pro Series 15's and 18's, American Standard 15's and 18's. I can't put up prices because of MAP.
