Speakerhardware.com
For member use only, no commercial ads allowed.
Re: Speakerhardware.com
#76 Post by LelandCrooks »
XTI in Stock. XLS Drivecore coming soon.
#77 Post by AntonZ »
That is nice, your business is extending beyond DIY hardware, congrats Image
Do you happen to know if the upcoming Drivecore amps will run on anything between 100V-240V and 50/60 Hz just like the XTi range? Looks like all of these exciting new affordable lightweight amps take their time arriving in European stores, so it might make sense getting one shipped from the US if it would run on local voltage.
#78 Post by LelandCrooks »
Pretty sure they will. I have specs somewhere from Namm, I'll see if I can find them.
Lots of big things coming pretty soon, to make it all easier. I'm slowly putting the pieces of the puzzle together.
mpm32
#79 Post by mpm32 »
Nice, I should've had you throw a couple of those in with the 42 1016s and crossover parts you just sent me. :)
https://www.facebook.com/CharlieDontSurfCT/
2-DR250
2-Wedgehorn 8
2-16" T39
bzb
#80 Post by bzb »
Nice, carrying XTis now!
I so want to get started on my new T39s, but I'm booked every Saturday (and possibly every Friday soon) until August! :( Or maybe :D
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Drey Chennells
#81 Post by Drey Chennells »
Very interested in the DriveCore amps... keep us posted!
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
#82 Post by LelandCrooks »
New stuff.
http://www.speakerhardware.com/categories.php?cat=128
I especially like these. http://www.speakerhardware.com/products.php?cat=130
They custom built the 1150 for me. My system has gone self powered. Pics pretty soon.
sine143
#83 Post by sine143 »
Oh Snap.... wow. that gives me something to think about.
I was eying your kits that were coupled with the xti's, but this is interesting as well
Side note:
you wouldn't mind sharing your settings for the xtis would you? If not, I understand, cause that's a definite point of attraction for the new guys looking to get into a plug and play situation.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
#84 Post by LelandCrooks »
The base curve is from the spl charts inverted. Then I apply my own tweaks, which I ain't sharing. :mrgreen:
NEW. I dropped my cable prices through the floor. 50ft pro grade xlr for under $30 for example.
http://www.speakerhardware.com/products.php?cat=124
Dave Non-Zero
#85 Post by Dave Non-Zero »
Those are some sweet kits! Nice. :)
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
sine143
#86 Post by sine143 »
Leland, although I've already realized this, you should tell everyone that the 3012lf is back in stock!
1x bastard XF208
#87 Post by LelandCrooks »
Crown XLS1000 is now in stock. http://www.speakerhardware.com/xls_1000 ... LS1000.php
New lower prices on the subwoofer and complete system packages. http://www.speakerhardware.com/products.php?cat=129
sine143
#88 Post by sine143 »
Do you have more detailed info on the xls crossover capabilities? Can you put both a lopass AND a hipass on 1 channel (to run... say, subwoofers?)
JBL users dont know what they are missing with your powered kits.
1x bastard XF208
#89 Post by AntonZ »
From the info on the Crown website it seems it does either HP or LP per channel, not both (no bandpass).
http://www.crownaudio.com/pdf/amps/XLS_ ... CRO137.pdf
http://www.crownaudio.com/pdf/amps/1421 ... 032410.pdf
Although I cannot find mention of it, there could be a default HP filter. But if so it would probably be set lower than most would need for pro sub operation. If not some purists probably find a reason to bash Crown for building an amp that "does not perform" at subsonic frequencies.
#90 Post by LelandCrooks »
I need to move some drivers. Almost all the guitar stuff on the site is on sale. If you use something besides bfm cabs and need some drivers drop me a line. Bargains to be had, especially on Pro Series 15's and 18's, American Standard 15's and 18's. I can't put up prices because of MAP.
