Simplexx 110 Build
Re: Simplexx 110 Build
Bass?
Das Jugghead
"The bass guitar[1] (also known as electric bass,[2][3][4] or bass) is a stringed instrument played primarily with the fingers or thumb, by plucking, slapping, popping, strumming, tapping, thumping, or picking with a plectrum, often known as a pick."
https://en.wikipedia.org/wiki/Bass_guitar
I've got a pretty good idea of what the bass is, and that Clapton doesn't play it.
- Rune Bivrin
I think you are actually thinking about Tony Iommi. Or possibly Django Reinhart.madmallard wrote: ↑Tue Dec 26, 2017 11:55 amisn't that how Clapton plays?Bill Fitzmaurice wrote: ↑Fri Dec 22, 2017 10:37 pm When the ripped up finger was finally healed it didn't work right anymore, so what I used to fret with that finger I had to learn to fret with my pinky. You'd be surprised what you can do when you have to.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
madmallard
no, the deal with only using a pinky on frets~ >_<
I've always used my pinky to fret when it was appropriate, the hard part is to re-train yourself to use it instead of your ring finger after 30 plus years of using the ring finger.
Das Jugghead
The good people at Colorship Media have some designs going and I hope to see some renderings this coming week. With the holidays and all I am trying to be patient but I am eager to get the cabinets back and play them!
What material are they using? Vinyl wrap won't have the required durability.
Das Jugghead
Yes they are vinyl wraps - the kind that go on vehicles. I guess I will see how careful I have to be with them. Maybe I can have a clear wrap placed over them as an added measure of protection.Bill Fitzmaurice wrote: ↑Sun Dec 31, 2017 4:31 pm What material are they using? Vinyl wrap won't have the required durability.
I've used vinyl wrap extensively. It's OK on a car, but I'd never use it on a speaker unless that speaker was going in my home to never be moved. You'll rip right through it in no time unless it's protected in transit with either a road case or a padded cover.
Das Jugghead
Bill Fitzmaurice wrote: ↑Mon Jan 01, 2018 10:40 am I've used vinyl wrap extensively. It's OK on a car, but I'd never use it on a speaker unless that speaker was going in my home to never be moved. You'll rip right through it in no time unless it's protected in transit with either a road case or a padded cover.
Interesting. I will have to see if we can put a clear vinyl wrap over them as well as added protection. Otherwise I will have to utilize a padded cabinet cover as you suggested.
On a separate note I saw the doctor at the hand center. They have ordered me scheduled for an MRI to see if there is damage to cartilage. I will know more toward the end of the month.
Das Jugghead
Hey Bill I have a question. I did a search but came up with nothing. If this has been asked before please forgive me.
Can a Simplexx 110 be paired with a Tuba 24? Had our first rehearsal today using old cruddy cabinets I had cobbled together from material I had laying around and I burned them up trying to keep up with the rest of the band. Before they went south the low-B sounded like mud and afterwards left me wondering about pairing a Simplexx 110 with a Tuba 24.
Thoughts, feedback, criticisms?
You could. The T24 plans show a 150Hz passive crossover that allows it.
Das Jugghead
Bill Fitzmaurice wrote: ↑Thu Jan 04, 2018 4:59 pm You could. The T24 plans show a 150Hz passive crossover that allows it.
Thank you.
Another question: Using BP102's do you recommend 1 BP102 in one cabinet or 2 Bp102's in the same cabinet?
Thanks again.
You can't V-couple one cab.
