Slim Tuba HT Trials
MissileCrisis
Re: Slim Tuba HT Trials
#76 Post by MissileCrisis »
I have to put it out there, that black finish you did @radian is jaw dropping :) I only hope to finish a cab in a similar glossy fashion some day!
@op: People also have done stains and striped colors with success, totally up to what looks good in the room.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
#77 Post by DJPhatman »
Why did you install the amp inside the THT? You know the amp is NOT air tight, right? Now, you have introduced a substantial area for response killing air leaks, not to mention ground loop hums. Here's hoping it works out for you.
kenkenni
#78 Post by kenkenni »
Hi Phatman. I have tested it and there is absolutely no air leaks and the amp is quiet as a mouse. You can't tell it's on.
I double and tripled check and the box is locked up tighter than Fort Knox even at the volume I tested it at everything
checked out good. The airtight gasket is doing it's job very well so far.
kenkenni
#79 Post by kenkenni »
Did a little more work to the slim THT. I have rounded the corners and sanded the entire cab.
I still want to go over a couple of the sides to get them smoother.
I also tested the cab again as I just found out my first connection to the Dayton amp was not
correct. Though it sounded good I wanted to make sure I didn't have a bad connection from the
amp. I read the manual and realised that when you connect the receiver to the low-level connection
of the amp you have to connect both the left and right channel using a Y- cable. I only had the left
mono channel connected before. After I connected the cables the proper way I was not prepared for
the sound that came out of this Tuba HT. The bass was truly unbelivable and now I could only set the
gain at about 4 on the plate amp as any amount more could have things falling off the walls and shelves,
even my precious LCD screen hanging in drywall above my fireplace. The movie I tested with it this time
was "Underworld Evolution". You can feel the bass in your chest and everything was vibrating even the
couch. And I am glad to say still no leaks with this new power being introduced in the cab. I can officially
say that yes this is a Tuba and it's what everyone has been describing. Thanks Bill for designing this.
Now I need to finish up so I can start on two Tuba 60 Slims for my DJ setup.
MissileCrisis
#80 Post by MissileCrisis »
You'll be the envy of all the local djs if you get those T60's up and running, no DJ I've seen/met in central California has bass of that caliber, not even the local rental companies (they tend to have low end pro gear). Good luck in all your future builds.
2 x TLAH
SLA Center
1 x 212 TH (custom)
#81 Post by Tom Smit »
Way to go! :clap:
kenkenni
#82 Post by kenkenni »
Thanks guys I will post pics of the cab's finished look eventually. Right now I am sanding the cab with 220 grit sandpaper and will coat the cab with
wood conditioner in preparation for it's face-lift.
