Curved SLA build with added jig
Re: Curved SLA build with added jig
That there is funny I don't care who you are.
2-Jack 10
2-Wedgehorn 8
1-Auto Tuba
2-Wedgehorn 8
1-Auto Tuba
- modernprimitive
Onkyo TX-NR818, SHS Audio SA2500, Cleanbox pro, Cerwin-Vega LS12s, Cerwin-Vega E-76 C, Cerwin-Vega H.E.D. 15" dvc driver in custom enclosure.
asarose247
thanks for a good looking build, lots of side bar discussion but for the record,
How much do you think it weighs?
- Ian Westwood
I'd guestimate in the region of approx 40 lbs ... ish.asarose247 wrote:thanks for a good looking build, lots of side bar discussion but for the record,
Leland, Ian:LelandCrooks wrote:Did this yesterday for a test. Cut through just leaving the top ply. I let it sit wet for about 30 minutes, just sprayed the top with a spray bottle. Worked perfectly. I'll fill the gap in the back with PL and make a brace nub that fits to the back of the baffle.Ian Westwood wrote:Ooops!
Probably didn't like being bent 2 ways! I wonder if water would help or ruin it?
Looking at this pic I might have cut too deep. Should have kept the last 2 plies untouched perhaps?
Have either of you made an actual bent-1 piece- baffle yet for a working speaker? If so, did you put the cut on the back of the baffle or the front? Any pics or lessons learned from it? I am re-doing my curved SLA with different drivers and am considering it.
- Chris_Allen
If I wanted a curved SLA, I would start with bending ply and glue three sheets together whilst clamped against two pre-cut curves, top and bottom.
With a router template for the driver size, I would route out a flat portion for mounting.
You can bend baltic birch if you're good.
