Re: David - Just For Fun
Posted: Tue Feb 15, 2011 3:38 pm
				Lookin' good Steve.
 I do believe the idea is to use them in a pair to replace a set of home speakers which I would like to do at some point in time. The horn shoots out both sides as seen here.chrapladm wrote:Are the Davids designed to be a Left and Right?
Meaning the exit horn?
Or do they both go to the left. Left as in the pic you provided.
I find that many MP3s, especially played off an iPod, have a lot of loss in the bass.... Usually much better from an original CD.baronvonsteve wrote:Connected my iPod to the Kenwood M2 and fired up the tunes.
might be the something going on with the player or the encoding since the highs are the ones that suffer. I keep all my stuff in lossless but for portable palyers, i encode at 128. They should sound identical except for other than the highs.chaywood wrote:I find that many MP3s, especially played off an iPod, have a lot of loss in the bass.... Usually much better from an original CD.baronvonsteve wrote:Connected my iPod to the Kenwood M2 and fired up the tunes.
CH
From Wikipedia...SeisTres wrote:might be the something going on with the player or the encoding since the highs are the ones that suffer. I keep all my stuff in lossless but for portable palyers, i encode at 128. They should sound identical except for other than the highs.chaywood wrote:I find that many MP3s, especially played off an iPod, have a lot of loss in the bass.... Usually much better from an original CD.baronvonsteve wrote:Connected my iPod to the Kenwood M2 and fired up the tunes.
CH
baronvonsteve wrote:I tried several sources with the same results.
Thanks, guys, but the MTM section is a bit hot for my taste but no complaints.
Explain? My SLAs that Steve and I built are very wide full dispersion and fairly minor horizontal falloff, but fairly narrow vertically. The David is fairly wide both ways now with our updated crossovers. However it does have a touch of noding vertically more of a problem when you pass through it that sit in the week spot. Very minor issue now but is noticeable in critical listening. If you just happen to be sitting in the bad spot you probably would never notice.chrapladm wrote:
Does the treble fall off when your out of the direct area like the SLAs?
I doubt it would, being that it isn't a SLA but I would rather ask.
Using test tones off a test CD it was more like +-5 for most off the range in the garage/shop with only the bass section being a bit week like ~-10+chaywood wrote:baronvonsteve wrote:I tried several sources with the same results.
Hello Steve,
Have you metered ? Is is flat from 35hz to 17k (+-3) like Goliath ?
CH
chaywood wrote: From Wikipedia...
Audio performance:
The third-generation iPod had a weak bass response, as shown in audio tests.
Have not metered yet. My ears tell me that the MTM section is even to it's self but is hotter than the sub. Remember, we changed Bill's crossovers to eliminate nodes. this gave us a hotter MTM. The system can be brought back in balance with some EQ. It seems that the sub can still take more power when the MTM is at it's limit. Still need to work that out but it's minor IMOchaywood wrote:baronvonsteve wrote:I tried several sources with the same results.
Hello Steve,
CH
