SLA Pro
bzb
Re: SLA Pro
#76 Post by bzb »
Bill Fitzmaurice wrote:
bzb wrote: I'd like to back them with the foam that Nimrod used, but I can't find that stuff anywhere in white.
Black foam behind the white grille would look very good.
I think it would too, but you don't think it'll attract too much attention? Inconspicuous is the word of the day.
I'm thinking it'd make it a little more difficult to do touchups later, too.
Have you had good luck painting grills with Duratex? Maybe thin it first?
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
el_ingeniero
Re: SLA Pro
#77 Post by el_ingeniero »
I'd consider semigloss out of a rattle can a better option. I'm not sure duratex would be able to get a grip on metal.
Re: SLA Pro
#78 Post by Tom Smit »
Is the foam paintable?
Re: SLA Pro
#79 Post by Bill Fitzmaurice »
bzb wrote: Inconspicuous is the word of the day.
Then do everything in beige.
DanielNY
Re: SLA Pro
#80 Post by DanielNY »
Use white speaker grill cloth to line the inside of the grill instead of foam. Tacks on the same way...
bzb
Re: SLA Pro
#81 Post by bzb »
Is so purdy, like-a-da nice greek yozurt
Suggestions on how to get this stuff to cure? We keep it around 67 inside the house. I have a space heater and I could drag a bunch of plastic in the laundry room, or is that a stupid idea?
Strangely enough, the white doesn't have the same strong smell as the black.
Bobby Shively
Re: SLA Pro
#82 Post by Bill Fitzmaurice »
Put it in the sun under a small 'greenhouse'.
bzb
Re: SLA Pro
#83 Post by bzb »
I'll do that as soon as weather permits, thanks.
The white is definitely a different beast. I'm 4 coats in and the patches are still visible. Not nearly as much texture as the black roller grade.
Bobby Shively
Drey Chennells
Re: SLA Pro
#84 Post by Drey Chennells »
maybe a Kilz primer coat?
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
Re: SLA Pro
#85 Post by Bill Fitzmaurice »
bzb wrote:I'll do that as soon as weather permits, thanks.
Odd. I sprayed my garage doors with it and coverage was 1 coat, no problem.
bzb
Re: SLA Pro
#86 Post by bzb »
Drey Chennells wrote:maybe a Kilz primer coat?
I actually sanded first, Kilz, then filled the holes and sanded again. The areas that have the patches you could see after 4 coats ever so slightly, but the fifth coat seems to have hidden it now. One more slightly thicker coat this evening should do it, then I'll let em bake for a few days if we have good weather.
Bill - I'm rolling them, since I already installed the foam... and I don't trust myself with the spray gun anymore. My last spray job of Duratex got messier than a drunkard with a gun of PL.
Bobby Shively
bzb
Re: SLA Pro
#87 Post by bzb »
Coated, caulked, wired... now they just need to be fired. In a kiln!
I'm definitely going with the black foam behind the grill. There's just too much white.
Bobby Shively
bzb
Re: SLA Pro
#88 Post by bzb »
Well, they look pretty good, but I have a minor issue. Even when the gains on the amp are at zero, I'm getting a strange, airy sounding hum from the piezos. I unhooked the woofers to verify, and it's only the piezos. Video for reference:
Think I wired something incorrectly? Here's my crossover:
Otherwise, when I crank one even just a little bit, they sound excellent. At first listen, I don't think I even need to EQ em. They weigh in at exactly 30 pounds.
Bobby Shively
Re: SLA Pro - almost done, annoying hiss/hum
#89 Post by Bill Fitzmaurice »
Tweeters don't hiss. Amps hiss.
SeisTres
#90 Post by SeisTres »
All I can say is....
you forgot to paint the big black round things :noob:
