Making a pair of TAT....
Padde298
Re: Making a pair of TAT....
#61 Post by Padde298 »
2 x TAT
#62 Post by Tom Smit »
Cool!
As an aside, you should rotate the top speaker cab so that the tweeters are together (both on the same side). Even better would be to have the bottom speaker standing up with the tweeter on top, and then place the other speaker on top of it with the tweeter on the bottom, such that the tweeters are together.
Padde298
#63 Post by Padde298 »
Tom Smit wrote: Mon Aug 06, 2018 8:28 am Cool!
Thanks. I realize the physical position of the individual cabs are not ideal. But as weight has to be kept as low to the ground as possible, the tops are on the side... Will try to turn them so the horns are over each other... Thanks!
2 x TAT
#64 Post by Seth »
Congratulations on getting that sorted out. If you ever find yourself bored and in need of some entertainment, here's a fun suggestion... put them both in the cargo area of an SUV and give them a listen :D
James Champer
#65 Post by James Champer »
Nice build.
Have you tried what Bill suggested if he were to use T39's? I would think that aiming the TAT's at the ground would not only have the two advantages he mentioned, but also add a "mystery" factor in that everyone will be looking around the bike wondering where the thump is coming from :D
Padde298
#66 Post by Padde298 »
James Champer wrote: Mon Aug 06, 2018 7:05 pm Nice build.
Could be fun to see all the nerds going around the bike to see where the bass is coming from...! :lol: Only under the platform are the batteries, power capacitor and amp. It would take a total rethink of the positioning of these items if the horns should be down fireing... I would much rather have a front fireing cab, like the T60/45...
2 x TAT
