https://youtu.be/7f_Ex0t4ii4
Does it work..?
Making a pair of TAT....
Re: Making a pair of TAT....
More bass, more bass!
2 x TAT
2 x TAT
Cool!
As an aside, you should rotate the top speaker cab so that the tweeters are together (both on the same side). Even better would be to have the bottom speaker standing up with the tweeter on top, and then place the other speaker on top of it with the tweeter on the bottom, such that the tweeters are together.
Thanks. I realize the physical position of the individual cabs are not ideal. But as weight has to be kept as low to the ground as possible, the tops are on the side... Will try to turn them so the horns are over each other... Thanks!Tom Smit wrote: ↑Mon Aug 06, 2018 8:28 am Cool!
2 x TAT
2 x TAT
Congratulations on getting that sorted out. If you ever find yourself bored and in need of some entertainment, here's a fun suggestion... put them both in the cargo area of an SUV and give them a listen
- James Champer
Nice build.
Have you tried what Bill suggested if he were to use T39's? I would think that aiming the TAT's at the ground would not only have the two advantages he mentioned, but also add a "mystery" factor in that everyone will be looking around the bike wondering where the thump is coming from
Could be fun to see all the nerds going around the bike to see where the bass is coming from...!James Champer wrote: ↑Mon Aug 06, 2018 7:05 pm Nice build.
Have you tried what Bill suggested if he were to use T39's? I would think that aiming the TAT's at the ground would not only have the two advantages he mentioned, but also add a "mystery" factor in that everyone will be looking around the bike wondering where the thump is coming from![]()
2 x TAT
2 x TAT
