Re: Nordo's Dual T39 Build
Posted: Thu Apr 14, 2016 9:05 am
Those look really, really good! Just wait until you hear them!
Did you have to do this to the top flange as well?Nordo wrote: Note the amount I had to trim from the flange around the opening to be able to slide the speaker in.
Hi GrantGrant Bunter wrote:Did you have to do this to the top flange as well?Nordo wrote: Note the amount I had to trim from the flange around the opening to be able to slide the speaker in.
Couldn't quite see in your pics...
Yes mate, it is a bit green out here at the momentNordo wrote: No, I only trimmed the flange at the bottom.
I slid the top edge of the driver in first, then scribed how much I had to trim off the bottom flange.
I don't think it comes up very well in the photo, but I undercut the piece of flange I removed, so that the shape of the cut followed the arc of the driver as I was lowering it in (does that make sense?).
Makes great sense
The flange of the driver was just scraping the timber flange as it was being installed.
This meant that I had trimmed away the absolute minimum amount of the cabinet's flange, as I didn't want any chance of leakage.
The Lab12 drivers came with a loose gasket which went between the driver and the cabinet's mounting flange which made sure there was no leakage at that interface.![]()
My next small job is mounting my mixer in the cheap little rack cabinet I bought.
I will fix the mixer to the cabinet with hinges. I just have to open up the mixer to make sure the mounting screws don't end up mangling a circuit board or something.![]()
I would use pop rivets rather than screws, much lower profile.
And I'd be more inclined to build a square frame to attach the mixer to, bolt the sides of the frame to the rack to act as a pivot at the front. That way, if you ever need to sell on the mixer, it's not full of holes in the mixer case.
Cheers
