Page 5 of 5
Re: 8x T39's
Posted: Mon Apr 02, 2012 6:02 am
by bitSmasher
12 posts on selling... :noob:
Have you finished these yet? I'm curious as to the P.Audio's performance. Though you don't have an Eminence-loaded cab to compare, would be good to share your opinion on the alternative driver.
Re: 8x T39's
Posted: Thu May 31, 2012 4:41 pm
by thomas
I feel like a right rebel with the way this tread has developed........... Anyway, all painted and just waiting for some metal grille to get here. Not tested at volume yet but results to come when thats done. Shape wise these are the nicest BFM subs i've ever build and I have high expectations for them, unfortuatly the Punisher vs T39 comp I've talked of isn't likely any time soon.
Re: 8x T39's
Posted: Thu May 31, 2012 4:43 pm
by thomas
It was a hot day by the way, im not addicted to pepsi max as those two photos may have you think.
Re: 8x T39's
Posted: Thu May 31, 2012 4:48 pm
by CoronaOperator
I see a jug of PVA glue next to the can of paint. Do you mix the two? A sound company around here does and I was wondering if you do as well.
Re: 8x T39's
Posted: Thu May 31, 2012 4:52 pm
by thomas
First few coats that are applied thinly with a smooth roller yes, i mix pva in. That paint (aldcroft/tuff cab) is water based so water should work fine to. Helps the paint go a little further since the PVA is cheap.
Re: 8x T39's
Posted: Sat Jun 02, 2012 1:17 am
by Harley
CoronaOperator wrote:... PVA glue next to the can of paint. Do you mix the two? A sound company around here does ....
What would be the benefit of that?
Re: 8x T39's
Posted: Sat Jun 02, 2012 2:33 am
by SirNickity
I think it "Helps the paint go a little further since the PVA is cheap." :lol:
Re: 8x T39's
Posted: Sat Jun 02, 2012 10:37 pm
by CoronaOperator
Harley wrote: What would be the benefit of that?
In the words of the guys at the sound company ... "It helps the paint stick better"
I also remember my grandfather would thin PVA glue with water and use that as a primer on bare wood to seal it before applying high gloss alkyd (oil based) paint.
I have no idea how much of a benefit it provides, just noticed now 3 people using the same technique. :confused:
Re: 8x T39's
Posted: Sat Jun 02, 2012 11:06 pm
by DJ Higgumz
What are you going to power these bad boys with?
Re: 8x T39's
Posted: Mon Jun 04, 2012 4:30 am
by thomas
Its getting powered with crown xs1200's.
