First build T39 16in wide - bp102
Saddle
Re: First build T39 16in wide - bp102
#46 Post by Saddle »
So I'm finally back at it. 9 weeks of not getting around to it because of a meniscus tear/breakdown in my right knee, and winter in general. .. Pictures to come.
Have a question about breaking in my BP-102.. actually the amp I'm going to use to drive it. I have a QSC USA1310 amp. Does it hurt this amp to run one side breaking in the BP-102 and nothing on the other side of the amp? I've read that Solid State amps aren't damaged if ran without a driver attached, but I've always been concerned about that..
So to answer my own question, I'll just attach a junk speaker and not drive that channel... duh.. :idea: :idea:
1x16 T39 - BP102 Almost Done!
Planned:
1x16 T39
Wedgehorn 6's
Pair Otop 12's
#47 Post by Tom Smit »
Saddle wrote:So I'm finally back at it. 9 weeks of not getting around to it because of a meniscus tear/breakdown in my right knee, and winter in general. .
Sorry to hear that.
Saddle wrote:Does it hurt this amp to run one side breaking in the BP-102 and nothing on the other side of the amp?
Not at all.
Saddle
#48 Post by Saddle »
Finally got some time to get back to this. As soon as I wire up the speakon jack connectors, and secure the wiring internally, I'm ready to put the side on. Because of some bowing of the wood when I put it together, There is a spot inside when I lay the side on that will have about a 3/32" gap. I can pull that down and should be good with it. The sealed chamber looks like it will be tight all around, but I will seal it up inside after the side is on.
What a project!!
Wedgehorn 6's next I think. We need monitors!!
Planned:
1x16 T39
Wedgehorn 6's
Pair Otop 12's
#49 Post by Grant Bunter »
Nice tidy build so far, keep up the good work!
Saddle
#50 Post by Saddle »
Grant Bunter wrote:Nice tidy build so far, keep up the good work!
Thanks Grant. I hope I can put the last side on it tomorrow. It will be a while before I get to the level of building and equipment you have in your Light and Sound setup. Nice Facebook page too!
Planned:
1x16 T39
Wedgehorn 6's
Pair Otop 12's
#51 Post by Grant Bunter »
Nah it's all smoke and mirrors lol
With the cabs, paint hides a multitude of patches.
Lighting hides the rest!
Saddle
#52 Post by Saddle »
Well, got the rest done and the side put on. So I think I just had a "Welcome to my World" moment with bondo... :wall:
Gee... How could a golf ball size of that stuff make such a mess! I used two plastic bondo applicators just mixing it. I used a lot of hot mud in the past, but this is like 5 minute mud! Proper ventilation means outside in a stiff breeze!! I can still taste it. But, dang... it sure fills in the holes...
I think I could tape a house with PL and make less of a mess. Glad it does harden. Even gladder that I have a lot of 80 grit sandpaper. Smaller amount, and a smaller knife to apply it with next time.
Still stinks! :noob:
Planned:
1x16 T39
Wedgehorn 6's
Pair Otop 12's
#53 Post by Grant Bunter »
Saddle wrote:Well, got the rest done and the side put on. So I think I just had a "Welcome to my World" moment with bondo... :wall:
Gee... How could a golf ball size of that stuff make such a mess! I used two plastic bondo applicators just mixing in. I used a lot of hot mud in the past, but this is like 5 minute mud! Proper ventilation means outside in a stiff breeze!! I can still taste it. But, dang... it sure fills in the holes...
Ha ha,
If your bondo is going off in 5 minutes, try just a little less hardener, and try not to overwork it when mixing. I get 7-10 minutes when I use it. Means I get at least one side and one top (or bottom) per mix and that's all filling screw holes...
Saddle
#54 Post by Saddle »
I used a little less hardener this time. Had more working time, and mixed it with a stick instead of the plastic paddle. Worked pretty well.
One quart is going to go a LONG way.. I'll have to find other uses for it other than this cab.
Planned:
1x16 T39
Wedgehorn 6's
Pair Otop 12's
djtrumptight
#55 Post by djtrumptight »
Saddle wrote:I used a little less hardener this time. Had more working time, and mixed it with a stick instead of the plastic paddle. Worked pretty well.
Yeah,other uses like on your next cabs,there will be others lol.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
#56 Post by DJPhatman »
djtrumptight wrote:Yeah,other uses like on your next cabs,there will be others lol.
Says the man who built some in Michigan's record-breaking winter, OUTSIDE ( :shock: )
You, good sir, win the CRAZY PHAT award! :mrgreen: :ugeek: :twisted: I've been--> :owned:
djtrumptight
#57 Post by djtrumptight »
Wow,im just seeing this lol. :lol:
2 SLA HT systems
2 SLA Pro's
