Page 4 of 8
				Re: New Build of Old-style T39s
				Posted: Thu Apr 18, 2013 7:34 pm
				by miked
				Did you roll or spray the primer on there, Bruce? They look darn good for just primer!!!  Nice, clean cab.  Your edges are perfect.
				Posted: Thu Apr 18, 2013 7:37 pm
				by doncolga
				Hey Bruce,
Those look great man.  Bravo!
When I win the lottery I'm going to drive my family out there in my RV and play keys with you guys.
Donny
				Posted: Thu Apr 18, 2013 8:03 pm
				miked wrote:Did you roll or spray the primer on there, Bruce? They look darn good for just primer!!!  Nice, clean cab.  Your edges are perfect.
Just rolled on with a cheap 6" roller.  It dries to fast that you can start the second coat as soon as you finish the first one.  I think the key is to get flat black.  I'm sure anything glossy will take longer to dry.
				Posted: Thu Apr 18, 2013 8:05 pm
				doncolga wrote:Hey Bruce,
Donny
That'd be fun!  And your girls would love Schlitterbahn.
				Posted: Thu Apr 18, 2013 8:10 pm
				Got two good coats of duratex on today.  That stuff is so amazing.....closed the lid on it just at a year ago.  Not a dry spot in the tub.
It is so easy to roll on, I couldn't imagine shooting it would give any better results and my cleanup took all of two minutes....and that's because I actually cleaned the roller so I can use it again when I finish the new v-plate,  Usually, I just throw it away.
Need to start breaking in the drivers....may work on that tonight.  Over the next couple of days, I'll put on the casters, jack plate, corners, etc.
				Posted: Fri Apr 19, 2013 3:36 am
				by 88h88
				Yeah I too opened up a year+ old tub and was surprised to find it was still perfect. Need to order some more soon though, a T60 eats a lot of the stuff.
				Posted: Fri Apr 19, 2013 8:41 am
				So, what's the minimum break-in time on a 3012LF?  It's being going for 12 hours with 10 volts at 30hz.  I did 24 last time.....was that overkill?
I'd kinda' like to button these up today.
				Posted: Fri Apr 19, 2013 8:48 am
				by Michael Ewald Hansen
				Bruce Weldy wrote:So, what's the minimum break-in time on a 3012LF?  It's being going for 12 hours with 10 volts at 30hz.  I did 24 last time.....was that overkill?
12 hours should cut it
				Posted: Fri Apr 19, 2013 8:52 am
				by miked
				I agree.  12 hours @ 10V/30Hz is sufficient.  Button those bad boys up and let'er rip!  Post pics too!
				Posted: Fri Apr 19, 2013 9:34 am
				miked wrote:I agree.  12 hours @ 10V/30Hz is sufficient.  Button those bad boys up and let'er rip!  Post pics too!
I'm gonna' let 'em run until I get everything else finished I guess.  That'll put a few more hours on 'em.
				Posted: Fri Apr 19, 2013 9:36 am
				Michael Ewald Hansen wrote:Bruce Weldy wrote:So, what's the minimum break-in time on a 3012LF?  It's being going for 12 hours with 10 volts at 30hz.  I did 24 last time.....was that overkill?
Thanks....I'm ready to put these to bed.
				Posted: Fri Apr 19, 2013 9:51 am
				by miked
				A request, if I may.  Would you please post some pics of the access cover once it's all buttoned up?  I'm collecting ideas for my build.  Thanks.
				Posted: Fri Apr 19, 2013 11:08 am
				miked wrote:A request, if I may.  Would you please post some pics of the access cover once it's all buttoned up?  I'm collecting ideas for my build.  Thanks.
Good timing.....that's next up on the hit parade.
This morning I finished up with the hardware.  Corners, casters, and jack plates.
I guess it's time to drop in the drivers and put on the access covers.
				Posted: Fri Apr 19, 2013 9:43 pm
				by miked
				Wow, you really did a great job on them, Bruce. They are sweet-looking.  I hope mine come out half as good.  Quick question: Any particular reason you went with the deep-dish jack plate vs a standard one?
				Posted: Fri Apr 19, 2013 9:54 pm
				miked wrote:Wow, you really did a great job on them, Bruce. They are sweet-looking.  I hope mine come out half as good.  Quick question: Any particular reason you went with the deep-dish jack plate vs a standard one?
When standing up, the cables hang a little nicer......that's about all I can think of....that, and you can put 'em closer to a wall.
I guess I just liked that look, so I made these match the first time around.
How's that for a real informative answer?
