Dubwoofer's Tuba HT build
Re: Dubwoofer's Tuba HT build
#46 Post by Bill Fitzmaurice »
Dubwoofer wrote:I had my voltmeter connected as I demoed the Tuba to a friend. If I had to guess, last night I was probably pushing about 35 volts :oops:
35 volts isn't going to bother anything per se. It's well below the driver Pe and Xlim, and chances are that there's not enough content at 20-25Hz for it to be reaching xmax either. I just say limit at 28v if you have a limiter as there's very little to be gained by running hotter than that.
maxmercy
#47 Post by maxmercy »
Difference between 28V and 35V: 2.5dB
If you need more low end, build another. +6dB.
JSS
