Duh, an open circuit is high impedance! Oh well, I was kind of close.LelandCrooks wrote:+1Rune Bivrin wrote:It's most likely a switching circuit, operating at 100+ kHz. If the voltage produced by the amp is too high - as determined by the in-circuit DSP - it will simply start switching on and off rapidly, with a pulse width that averages to the limit. Capacitors and inductors will smooth that, although close enough to the driver that isn't very important. Pretty much the same as a Class D amplifier.
D-Fend
Re: D-Fend
SirNickity
Re: D-Fend
So you're thinking the "resistance" is actually an intermittent (at kHz speeds) open circuit? Interesting concept.
Re: D-Fend
Not really resistance (unless you call it an open circuit), but rather impedance.
It's also a way to get LEDs to go dimmer....by limiting the power through on/off switching. (LED would be "off" more than it is "on" which results in less light output in the same time frame, and therefore appears dimmer.
nastyford77
SirNickity
Re: D-Fend
That's exactly what it is.
JerryAllen
Re: D-Fend
Did this product go by the wayside?
Jerry
Jerry
Re: D-Fend
I hope not.JerryAllen wrote:Did this product go by the wayside?
Jerry
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
Re: D-Fend
No. Bringing something like this to market is hard. Really hard. Considering the market it's aimed at, it has to be right the first time. Pro sound is unforgiving.
Re: D-Fend
FWIW, I have one of the early evaluation units. The good news is that it works, the bad news is that it seems the instructions were written by the same person who wrote those for my DEQ 2496, as they're just as worthless. If you aren't an engineer you can't figure out what the hell they're talking about. I am an engineer and barely deciphered them.
JerryAllen
Re: D-Fend
I got a response from Eminence..... the units are in FCC testing right now.... possibly mid October 2012.
Used with permission from the author.
JerryJerry,
Yes, it will be available in the US. The unit is off at FCC testing right now. As soon as we get the official "all clear" from them, we will start production. It will take about a month to get the boards built and into production here at our plant in Eminence. Assuming we get the board back from FCC in the next couple of weeks, we should be in production by mid-October. This unit I'm describing is our D-fend Stand Alone unit that will come in a little enclosure that can be mounted to the back of any speaker cabinet to retrofit the existing systems. If you have any other questions, please let us know. Thanks! Take care!
Regards,
Josh Martin
Re: D-Fend
That can't be good. Bad documentation leads to incorrect settings which leads to believing your speakers are protected. The first guy who jams 100 volts into something and sees/smells smoke out of his cab is gonna be pretty PO'd. Or maybe it's his own damn fault for not limiting properly in the firstBill Fitzmaurice wrote:FWIW, I have one of the early evaluation units. The good news is that it works, the bad news is that it seems the instructions were written by the same person who wrote those for my DEQ 2496, as they're just as worthless. If you aren't an engineer you can't figure out what they hell they're talking about. I am an engineer and barely deciphered them.
T39 - Dual BP102 23"
AutoTuba
J12 x 2 - Deltalite 2512
O12 - Dual BP102
AutoTuba
O12 - Dual BP102
Re: D-Fend
IMO these should not be released until they've written instructions that make sense to the average user, and I told them so. It remains to be seen if they do so.dheafey wrote:That can't be good. Bad documentation leads to incorrect settings which leads to believing your speakers are protected. The first guy who jams 100 volts into something and sees/smells smoke out of his cab is gonna be pretty PO'd. Or maybe it's his own damn fault for not limiting properly in the firstBill Fitzmaurice wrote:FWIW, I have one of the early evaluation units. The good news is that it works, the bad news is that it seems the instructions were written by the same person who wrote those for my DEQ 2496, as they're just as worthless. If you aren't an engineer you can't figure out what they hell they're talking about. I am an engineer and barely deciphered them.place.
Re: D-Fend
Would you recommend this kind of processing over the usage of drpa or the such for the small scale enthusiast? Did you get any picture on how the processing sounded, compared to digital/line level processing?Bill Fitzmaurice wrote:IMO these should not be released until they've written instructions that make sense to the average user, and I told them so. It remains to be seen if they do so.dheafey wrote:That can't be good. Bad documentation leads to incorrect settings which leads to believing your speakers are protected. The first guy who jams 100 volts into something and sees/smells smoke out of his cab is gonna be pretty PO'd. Or maybe it's his own damn fault for not limiting properly in the firstBill Fitzmaurice wrote:FWIW, I have one of the early evaluation units. The good news is that it works, the bad news is that it seems the instructions were written by the same person who wrote those for my DEQ 2496, as they're just as worthless. If you aren't an engineer you can't figure out what they hell they're talking about. I am an engineer and barely deciphered them.place.
I wonder if the stand-alone and rack-mount units will have some kind of digital remote for setting the filters to make it more user friendly...
Re: D-Fend
From what I can gather, I think they have a serial port connection for setup parameters. Once you set it up for a particular driver, there's no need to change it in the field.
My biggest thought is: I wonder how much limiting it will do before it becomes audibly objective? The duty cycle of signal off time vs on time would have to remain fairly low to be inaudible. I wonder how much back EMF there is across the voice coil when the defend opens the circuit?
Most likely this would still be used in conjunction with DSP limiting, the Dfend being the last line of defense against driver failure.
If Bill had the opportunity to evaluate one, I'm sure he can fill in some of the gaps.
T48s
WH8s
SX212
T48s
WH8s
SX212
Re: D-Fend
The unit I have is an evaluation unit, not the finished product, so I can't say how that will work.byacey wrote: If Bill had the opportunity to evaluate one, I'm sure he can fill in some of the gaps.
