BEHRINGER iNUKE NU3000
				Chris Betancourt
Re: BEHRINGER iNUKE NU3000
Have your tried the amp for mids and highs???
									Christopher Betancourt
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
Puerto Rico
On the table:
too much work!! LOL
Future:
No, just on the CDs.  The mids are already well catered for and it's a PITA to swap it all over.
Yes, I asked at Behringer and got this answer:Dave Non-Zero wrote:Anyone know the actual RMS power ratings on these amps? It seems up in the useable territory.
NU3000 - approx 580W RMS @ 4 ohms per channel
NU3000 - approx 310W RMS @ 8 ohms per channel
				bassmonster
Hmm, 580w RMS at 4 ohms? If that's true, that's not bad at all for the price.
				bassmonster
Question, would this amp be enough to sufficiently power two otop 12's beta 12a-2 loaded on one channel and two t30 lab 12 loaded on the other channel?
				el_ingeniero
prolly enough for the Otops, but wouldn't put the T30s as hard as they could go.bassmonster wrote:Question, would this amp be enough to sufficiently power two otop 12's beta 12a-2 loaded on one channel and two t30 lab 12 loaded on the other channel?
				bassmonster
All the magic happens in the first 100w though right?el_ingeniero wrote:prolly enough for the Otops, but wouldn't put the T30s as hard as they could go.bassmonster wrote:Question, would this amp be enough to sufficiently power two otop 12's beta 12a-2 loaded on one channel and two t30 lab 12 loaded on the other channel?
About same specs as XTi 1000... on the T39s/T30s it's just not enough voltage to take advantage of the 3012LF/Lab12.
IIRC, 100W to 450W is ~6dB. A good chunk of "loudness" you're missing out on when you get up there.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
It's still working!
						- Dave Non-Zero
I used one the other night to run a couple of kickbins. Didn't have the juice really. But I'm really tempted to buy a couple for a light weight monitor rack. Can't believe how lightit is! One finger light!
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
						Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
When I first took mine out of the box it felt as though the case was empty, it's that light.
						- subharmonic
Unless you want headroom. If you need to push your amp hard just to get to regular volumes then that is not the amp you want.bassmonster wrote: All the magic happens in the first 100w though right?
I need more bass
CW Mcall
						I need more bass
CW Mcall
Yes the magic happens with the first 100W, but you need another 300W to get 6dB of headroom. Or twice as many cabs and two amps.
I'm glad to report that it's still working well.
