I would have had to shave down the face on the corner protectors or tweak the back panel to make it removable. Plus it would have looked goofy on the front with the corners overhanging the horn (not goofy like it does now, but bad goofyBill Fitzmaurice wrote:They'll even work with 1/4" panels. You just need to prep the cab properly, with a 3/8" radius round-over router bit.cheapbasslovin wrote:The truth on the corners is I bought them locally and thought they would work on the 1/2 inch. When I put them up against my cab they were clearly set up for 3/4 or bigger.
Jack 210 build. Noob builder. Confidence :::returned:::
- cheapbasslovin
Re: Jack 210 build. Noob builder. Confidence :::returned::
Mrrmensneturguneffferremantun
- Doug Hart
Love the corners !!!
Doug Hart, Owner
dB Pro Audio
http://www.hartdesignsetc.com
dB Pro Audio
Just pull the corners when you need to pull the back. PITA if you pull the back weekly, but why would you?cheapbasslovin wrote:
I would have had to shave down the face on the corner protectors or tweak the back panel to make it removable..
- Harley
I would imagine this was to give a bit more meat to screw into rather than just 1/2" ply.wounded horse wrote:Those stacked out corners look like you're planning to go over niagara falls in it. What's the thinking on those?
- cheapbasslovin
This just never even crossed my mindBill Fitzmaurice wrote:Just pull the corners when you need to pull the back. PITA if you pull the back weekly, but why would you?cheapbasslovin wrote:
.Harley wrote: I would imagine this was to give a bit more meat to screw into rather than just 1/2" ply.
Maybe it could be, but I only used 1/2" screws on it.
Looks great! Are you going to make a rack case for that Peavey head the same color?
Once you go Jack, you never go back!
Done:
(2) Jack 12, 3012ho, Straight Array with On/Off Switch
In Process
(4) Dr200 Beta 8, Melded Array
Done:
In Process
- cheapbasslovin
That is the plan. I also have a bass refinish project that I'm going to give a whirl in that color, and if I have enough left after my 110's then I might also do an effect/ accessories case in that color. No more questions over whose gear that isDantreige wrote:Looks great! Are you going to make a rack case for that Peavey head the same color?
I thought Barbie had an elevator on her dream mansion
That's actually pretty sweet.
BASS: Combo Amp & Titan39
- cheapbasslovin
I was going to get all offended, but then I noticed it was an astute observationGauss wrote:I thought Barbie had an elevator on her dream mansion![]()
Thanks to everyone for the kind words.
I thought it was England going to the dogs, but now BFM thinks Barbie's mansion looks "way cool". Time to start packing heat.Bill Fitzmaurice wrote:... but IMO it also looks way cool.
- cheapbasslovin
Good lookin' cab!
Did you EQ for flat, or is a personal preference?
- cheapbasslovin
Thanks!
I think I was going for the reverse response curve before I just started tweaking away. I dropped everything above about 2.5k since I don't have my piezos installed. I don't have any measuring equipment, so flat is really just a mystery to me. I just tweak it till I have the frequencies I want and dump the freq's I don't.
I still haven't gotten it into a jam setting, so I don't know how I'm going to like the EQ yet. I do like standing in front of it with loose fitting pants. I haven't had a pant flapping rig in a while and it's pretty fun
