First Build: Omni Top 112s
Re: First Build: Omni Top 112s
They look pretty, but from a performance standpoint what matters is minimizing the frame space between the individual horn mouths. One may drill new holes to aid in their mounting.
Ahh, I see. I'll have to shim down my jig a tadBill Fitzmaurice wrote:They look pretty, but from a performance standpoint what matters is minimizing the frame space between the individual horn mouths. One may drill new holes to aid in their mounting.
Also, you may try alternating the position of your piezo's. So the three screws on the back element do not interfere with the neighbouring element. And you can get them even closer together. Like so:
When I did the arrays for my DR250s, I glued each side up, then cut the 45s as full units.
I found the angle would match up better if I did it that way.
Shimmed up my cute little tweeter jig:
Then recut to the narrower height:
Then clamped a saw sled up to the kitchen counter top and began to glue up tweeters in pairs before 45 degree cuts:
Results pics to follow; not too pleased with the paint outcome - plastic primer + lacquer =
My first melded array:
And, almost forgot to take pics before painting:
Painting in the kitchen???!!!
What, oh what, is she going to say??
Heh; same thing she said when I PL'd in the kitchenTom Smit wrote:Painting in the kitchen???!!!![]()
Actually, that's her hand next to the can of paint. I tried to include her on some aspects of the build. Painting, however, did not seem to be one of her favorite things. Learn somethin' every day
I get the same sort of thing when trying to repair something at the kitchen table, LOLripNdeb wrote:Heh; same thing she said when I PL'd in the kitchenTom Smit wrote:Painting in the kitchen???!!!![]()
