Jig for trimming plastic stackable corners?
coolhandjjl
Re: Jig for trimming plastic stackable corners?
The corners look silver, the cab looks battleship grey. Perhaps its because the photo is a tad light to show the shade of the cab. It also looks like the camera flash is highlighting the texture of the plastic quite a bit, making it look lighter than actual.
John Luke
Pair of Omni 212's
Pair of Omni 212's
How long you had this on? Results?DJPhatman wrote:I use the black DAP® DYNAFLEX 230® Premium Indoor/Outdoor Sealant Leland used to sell. Just enough to hold the corners to the cab.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Use carefully, as it oozes everywhere. But, it works very well. Put a thin coat on the underside of the corner, install it with 1/2" screws, clean up any ooze. I have 1 cracked corner (happened this fall when "gorilla" step-son dropped my frozen O10!bzb wrote:How long you had this on? Results?DJPhatman wrote:I use the black DAP® DYNAFLEX 230® Premium Indoor/Outdoor Sealant Leland used to sell. Just enough to hold the corners to the cab.
- Harley
He needs to learn "Gorilla Grip"DJPhatman wrote:happened this fall when "gorilla" step-son dropped my frozen O10!![]()
gdougherty
So are you using the Dynaflex to fill in all the empty space and add some extra density to the corner?DJPhatman wrote:Use carefully, as it oozes everywhere. But, it works very well. Put a thin coat on the underside of the corner, install it with 1/2" screws, clean up any ooze. I have 1 cracked corner (happened this fall when "gorilla" step-son dropped my frozen O10!bzb wrote:How long you had this on? Results?DJPhatman wrote:I use the black DAP® DYNAFLEX 230® Premium Indoor/Outdoor Sealant Leland used to sell. Just enough to hold the corners to the cab.)
More like an adhesive backing to give extra bond and strength. But, yes it fills the gap.
The step-son is very ADHD/ADD. From the moment he wakes up, until late in the evening, he goes like a cartoon character. But he is also impatient. That's how he dropped my O10. In a rush, didn't have a good grip and slipped out of his gloved hand.
