Melded Array Wiring Help
David Carter
#31 Post by David Carter »
fender3x wrote:This is low tech to the point of absurdity, and I am glad no one was there to watch me do it, since I am sure I looked pretty silly.
Worked for me! See the paint roller on the desk? That's what it was used for. :)
Dave
- 2 x Titan 39 (BP102 - 14"W)
Tim A
#32 Post by Tim A »
Paint roller is a good idea, the fur would help knock out the surrounding tweets.
I use a paper towel roll sometimes, but never a toilet tissue roll, everyone knows they suck tone.
I'm also a big fan of the Christmas wrap roll if there's enough room.
I tried an aluminum foil roll once but it sounded...tinny.
I tried a wax paper roll once. It worked pretty slick...
I kill me. :lol:
Tim Collins
#33 Post by Tim Collins »
Do you all solder straight to the lugs instead of using the little connects? If so, would a 15w iron and 60/40 rosin suffice?
#34 Post by Bill Fitzmaurice »
Tim Collins wrote:Do you all solder straight to the lugs instead of using the little connects? If so, would a 15w iron and 60/40 rosin suffice?
A 15w iron is too small. It takes so long to heat the joint that it damages piezos. I use a 50 watter.
