First BFM Build Odyssey: Tuba 60
Re: First BFM Build Odyssey: Tuba 60
#31 Post by Seth »
Joman116 wrote: Thu Apr 02, 2026 2:36 pm Thanks Billy.
Billy?
You guys playing tether ball down by the swing set later?
Race ya to the monkey bars!
Joman116
#32 Post by Joman116 »
Seth wrote: Thu Apr 02, 2026 3:34 pm
Billy?
Ha whoops. Autocorrect. *Bill!
QSC 1804 Amp
In Progress: 1x20" Tuba 60 loaded with Eminence Lab12
Joman116
#33 Post by Joman116 »
So I was actually able to get the side panel cut out today. It's a little bit rough as I freehanded some of it. Should be able to look much better cosmetically at the end of the build where I sand it and will finish it.
Getting an HTTP error when I'm trying to upload image.
Next I'm going to do the baffle cut out driver, Target is prior to Easter.
QSC 1804 Amp
#34 Post by Seth »
Joman116 wrote: Thu Apr 02, 2026 4:11 pm Ha whoops. Autocorrect. *Bill!
:mrgreen: figured that was the case.
I had a few glitches occur on this site today too. They cleared up. Maybe try uploading again tomorrow.
Joman116
#35 Post by Joman116 »
A few pics of the panel cut and the jig I'll use for the hole.
If the hole requirement per plan is 10 3/4" for lab 12, do I add 1/4" to account for the bit diameter? , thus putting in 11" for the Jasper jig?
Edit : I read The Jig more closely and it says it's calibrated already to use a quarter inch bit, so in this case I choose the 10 and 3/4 in slot
QSC 1804 Amp
Joman116
#36 Post by Joman116 »
Made progress yesterday! Decided to jump around from the plans, instead of gluing the first panel I decided to work on the baffle. The Jasper Jig was crucial, thanks to the person who recommended that, it was either Bruce or Seth I believe.
First time using a router so the setup for the router and The Jig took quite some time. Cut the circle in one pass. I need to do some visual inspection to make sure the speaker surround is not hitting the baffle when there's voltage applied (using the lab 12)
QSC 1804 Amp
#37 Post by Bill Fitzmaurice »
It's easier to cut the hole with multiple passes, going through it in one pass bogs the router down and overheats the bit.
Joman116
#38 Post by Joman116 »
Bill Fitzmaurice wrote: Tue Apr 07, 2026 8:14 am It's easier to cut the hole with multiple passes, going through it in one pass bogs the router down and overheats the bit.
Will keep that in mind for next time, yes it did sound like it was bogging down a bit. Circle looks quite good though.
QSC 1804 Amp
Old Mike
#39 Post by Old Mike »
I'd add a suggestion, fasten the board you are routing the hole through down to a sacrificial base via some screws through the piece that will be discarded, by doing that when the router breaks through it won't damage the edge of the hole you made.
#40 Post by Bruce Weldy »
Absolutely......and it's actually much quicker. You can do 2-3 passes pretty quick and not burn up the router or the bit.
Joman116
#41 Post by Joman116 »
Still working on the baffle. Decided to do the break in process for the lab 12, per the plans. My amp is a QSC plx 1804.
Not going to lie I don't have experience with speaker Excursion outside of an enclosure, so it's a bit nervous feeling when I see the surround flexing a lot. A quarter turn of the amplifier is yielding about 3 volts. The source is my laptop sound card. I suppose the amplifier knob is not linear..
QSC 1804 Amp
#42 Post by Bill Fitzmaurice »
It's not supposed to be linear, it's supposed to be logarithmic. Doubling of volume isn't twice the power, it's ten times the power.
Joman116
#43 Post by Joman116 »
Bill Fitzmaurice wrote: Mon Apr 13, 2026 9:16 pm It's not supposed to be linear, it's supposed to be logarithmic. Doubling of volume isn't twice the power, it's ten times the power.
What I meant to say was the actual knob on the amplifier.
I found out what I was doing wrong. My source is a laptop which signal is very weak. Switch to go through mixer to Output 0 decibel to the amp. NOW we're talking, getting 15 bolts with a quarter turn. Break in is complete.
Need to make the small rectangular anchors to secure the driver into the baffle. Hopefully I can get to that tomorrow. I did a test fit to see if the driver smacks against the baffle, looks okay so far.
QSC 1804 Amp
Joman116
#44 Post by Joman116 »
Oh and a pic below.
QSC 1804 Amp
#45 Post by Tom Smit »
Nice pic. Looks good.
