Page 3 of 4
Re: Tuba 45 Build
Posted: Thu Feb 11, 2021 1:58 am
by Pabloaguas
More pics before lids go on
Re: Tuba 45 Build
Posted: Thu Feb 11, 2021 3:35 pm
by Seth
Paul and Rob... that's looking really good.
What a great job. The build quality is very apparent in the photos. I really hope the results meet your expectations, given the few modifications to the plans.
One thing I thought I'd mention... it's not something I've experienced personally, but it's come up in conversation a time or two. You'll note that the plans advise screws to secure the drivers. IIRC, the plans were modified a few years back to screws and retention blocks, from bolts and hurricane nuts because they hold better without backing out as much and they wont cross thread, push out the back side, or strip and spin as easily. I was thinking thread locker would be good to keep them from backing out, but it could also contribute to spinning the inserts at a later date. What's done is done, and I'm sure you'll handle it appropriately if it ever becomes an issue. Really, I just mention it for the benefit of casual viewers/future builders to be aware of.
Other than that little tidbit... I'm super excited to hear of your impression once they're all buttoned up, painted, and tested/in service.
Re: Tuba 45 Build
Posted: Sat Feb 13, 2021 11:48 pm
by Pabloaguas
Yes, we went with the double baffle and 1/4" lag bolts. Torqued them to 5.5nm. They do not protrude through. They should hold fine as long as the gasket on the woofer doesn't shrink...
Re: Tuba 45 Build
Posted: Sat Feb 13, 2021 11:49 pm
by Pabloaguas
Final coat curing:
Re: Tuba 45 Build
Posted: Sat Feb 20, 2021 2:35 pm
by Pabloaguas
MIND BLOWN!
Dang these things sound good! And loud! Havenβt gigged with them yet but they sound great and powerful in the living room. Might even sound better than my old ACI Titan II Le. They really have that concert bass sound like horns that professionals use at large concerts. Sound is clean and responsive down to 30hz with a simple 6db boost at 30hz. Canβt wait to gig with them!
Re: Tuba 45 Build
Posted: Sat Feb 20, 2021 4:55 pm
by himhimself
Way to go, you'll soon see how awesome they sound unleashed at a gig!
I love my T30's. Can't explain until you experience the difference.
Re: Tuba 45 Build
Posted: Sat Feb 20, 2021 11:00 pm
Way to go!
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 3:42 am
by Chris_Allen
I've spotted a problem with your T45's......... You don't have enough of them
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 4:29 am
by Grant Bunter
What is the high pass for less than 4 cabs with T45's?
I see a pic of a driverack, that's great.
I'm assuming the high pass is the same as T30's, 35Hz for less than 4 cabs.
If you're high passing at 35Hz, but boosting 30Hz by +6dB (double the power) is AFU
If you're high passing at 30Hz, with less than 4 cabs, is AFU
If you're really "needing" 30Hz at +6dB, add two more cabs, high pass at 30Hz, and you will have it, but that will also raise everything else by +6dB, so where does it stop?
I can't see the point in employing someone to build your cabs, then keep on blowing up drivers, because that's what will happen.
Sorry to come on so strong about it, ask as many questions as you like, but a show with no subs all of a sudden will hurt somehow, pocket or reputation...
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 8:48 am
+6dB is four times the power. So long as the voltage limit isn't exceeded that's OK, but it will skew the response away from where most bass content lies, which is between 50 and 70Hz.
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 3:58 pm
by Pabloaguas
Bill Fitzmaurice wrote: βSun Feb 21, 2021 8:48 am
Yes- high passed at 30hz 48db butterworth. Playing test tones at 25, 30, 35 and not exceeding the voltage limit at all with the limit set on the drive rack.
These things really rock Bill. So much great sounding bass in a relatively small, lightweight package. Absolutely blows away front-firing subs. Thank you for your excellent design
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 4:22 pm
Now you can imagine what the T60 will do.
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 5:44 pm
by Pabloaguas
Yes! Iβm actually dreaming of creating a T90... doubling the scale of the T45 for an almost 8βx 4β x 4β Tuba. Build with 3/4 BB ply. Would fit perfectly as a permanent build into a 4x8 trailer. Load with two high-excursion 15β woofers and have rack mounts for amps in the space between panel 4 and 5.
22β foot horn length, and Almost 16 cubic feet of mouth area. High pass at 17hz. Low pass at 60hz. Pure bass bliss.
Would be convenient for outdoor venues- just drive it in, plug in and open the trailer doors. Or hand-wheel (push) into venues that have > 5β Wide doors.
The tuba trailer.
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 5:48 pm
by Pabloaguas
But really, Iβm impressed with how low the t45 plays and how much output and control it has at low frequencies. These two T45s were the prototypes and now that we have confirmed that we are happy with the sound we Will probably build a batch of another 4-8 T45s later this spring.
Re: Tuba 45 Build
Posted: Sun Feb 21, 2021 6:06 pm
Don't bother with going any lower than what the T60 will do, there's nothing down there to reproduce. Having mains capable of going to 60Hz is a waste of cartage as well.
