Re: Tuba 30 CNC build
Posted: Tue Dec 19, 2017 5:57 pm
After doing the test fit I felt like I should be able to pass the parts over to other members of our group for construction. After doing that and nothing happening for a few weeks I organized a workday to get things going. Well that turned into quite the fun afternoon with five guys. After a good amount of me convincing everybody to follow the build plans we got going and made some progress. Too many cooks in the kitchen!
In installing panel one we tried using just brads on the joint in the dado (between panel one and the side panel) but ended up putting screws in the pilot holes made for transferring the plan to the second side panel in order to hold the first panel in place properly. I think this all would have been easier to keep things in place and square if I had made my right angle jigs like 3 or 4 inches tall instead of 2.
In this first session we also got the mounting the blocks glued to the baffle as you can see in the pic.
I didn't take pictures of it but the next day we pulled the screws holding the mounting blocks from the baffle and test fitted the driver using 2" #10 hex/slot head screws. They are a bit long and poke through the mounting blocks but all that will be covered so no big deal I think. Right now the driver is humming away with a 30hz test tone at 9.4V. As far as I can tell it's not rubbing.
Actually I have a questions about this test. What's the purpose of running it for 12 hours? Is the idea that the driver will loosen up a bit and could start running later in the break-in period?
Also, there is a gasket on both the front and back of the Kappalite 3012LF which the specifications say are both sealing. In your experience will I have to run caulking around the edge of the basket to get a good seal or is the one in there good enough? Do I need to apply gasket tape?
Hopefully later this week we'll be adding some more panels!
