I'll start by saying that please remember english is not my main language and I agree with all that's being said and truly appreciate. I'm not trying to confront or disagree with you, I'm asking for your opinion because we really need your help.
we'll stop the build until we find such a glue! You've scared me enough. And if you say the simplest solution is just to scrape the existing glue and just cover with a bead of PL, then that is exactly what We'll do.
I'm still not quite certain what you mean by "expanding" adhesive. it means if I leave it overnight to glue the squeezeout will be bigger in the morning?
or in the case of the picture I posted, there should squeeze out a bit over time and since ours didn't it's not expanding?
I've found out that basically Soudal and and Pattex and all those brands (including Loctite) have different product names in Portugal.
if you go for example to Soudal's PT page
http://www.soudal.com/soudalweb/product ... =636&g=857 )
you'll see that no 60A exists. There is although a PU Construct EXTRA Fast and a PU-Bond 2K.
that's the "professional" products.
there's also a "consumer" page but products mostly have a portuguese name instead of a code.
http://www.soudal.com/soudalweb/product ... =639&g=897 ).
Ours is "Cola e Veda" which roughly translates to Glue and Seal.
The result is the same with all other webpages. different names and labels but probably the same products with a different face.
I'll start looking online for glue but I'm struggling not to find nothing with such a big offer around me.
(and I can buy them for less than 5€ instead of paying 15+ per each).
Maybe I should email Soudal PT and wait for them to tell me what's the 60A equivalent ?
Any help appreciated. Cheers
EDIT:
I think I finally have one !!
Sika Bond T2.
Here's the official product description
High viscous (thixotropic), high strength elastic adhesive
1-part, Polyurethane ready to use
Powerful initial grab (green strength)
Fast curing
No need to grout the bonded parts
Strong adhesion to many different substrates
Elastic, sound-dampening adhesive
Reduces vibrations (vibration- and shock resistant)
Compensation of substrate unevenness
Non-corrosive and avoids galvanic corrosion
High weathering- and ageing resistance
Adhesive can be sanded
Tests
Approval / Standards Bonded part instant holding capacity (C.E.B.T.P. Report N° 2352-7-270).
Acoustic insulation to piping vibration (C.E.B.T.P. Report N° 713-970-0011).
This is for sale near us. It's about 15€ per 310ml but I guess it's better than having leaks !
