Thursday night's progress:
Managed to get quite a bit done last night.  Got panel 3 in place and I was about to install panel 4 when I saw my scrawled note from a few nights ago on the sub... "Install Lab12 reducer panels before 4".  It seemed like a much better time to install them whilst I still had good access into the driver chamber - and so it proved.  I used MUCH less PL with the perpendicular (the 10"+ one) reducer panel as well - I could slightly tease panels 2 & 3 outward and get the extra panel in there, rather than them being rock solid due to them being attached to #4.  As I was running low on wood, and the reducer panels are only 'thin', I butchered my circular saw sled for wood - it was 30.25" long
   This was the second sled that I made, but after making it, I found that the first one was waay more accurate.  The first was made out of cheap 'exterior ply' with the dreaded thin veneer, but that stuff
does not warp! (that doesn't mean you should use it for the actual sub though
 ).  The second was made out of BB and it was all over the shop with the warping!
I managed to get panel 3, and the 2 reducer panels installed as well as getting panel 4 cut to exact size before I decided that was it for the night.  I did want to get panel 4 installed but I realised that I didn't want to install this panel next.  This is because last time, installing the flanges with the reducer panels in place is a proper pain and so I am going to install the flanges whilst I have good access into the chamber.  If you look at the bottom pic, I can simply cut a triangular piece of wood to make a flange and then glue it in place from the 'inside' of the cab.  Not only will this be easier to fit, but far stronger too.  I will be doing the same behind the other reducer panel also and I'll have nice solid flanges.  I will probably complete the rest of the flange tonight as well.  Last time, I hadn't even scraped off the squeezeout behind those reducer panels when I installed the flange as I was
following the plans... to the letter
  It was a proper PITA to do as there was no way to get in behind those reducer panels to remove the squeezeout once the second side was attached.   I had to sand down a corner of my flanges so that it missed the squeezeout... which resulted in weaker flanges.  Would there be some way of suggesting edits to the plans to allow these things (or others things that other people may have spotted) to be included in the next revision?  I am sure I could alter them in 5 mins, send them in to Bill for approval/rejection and they could then be included/binned(!).  I am sure with some forum help, we could make the plans even easier to build.  I'd be happy to sign my rights over to Bill for my edit, as I'm sure others would be.  I don't know however if Bill would be happy to:
a) have to trawl through edits, although they could be discussed here first amongst members to weed out the rubbish/impractical and:
b) allow others to edit his I.P./creations... those plans are his babies and he may not like some bloke coming along and changing them.
If no, then that's cool.  I was just thinking it could be a way for the experience gained from hundreds of builds to be put back into the plans.  I'd be well happy to see my edit in the plans
So without further ado, here's the progress from last night:
Over the weekend, I will complete the cab build apart from the top (8), back (10) and bottom pieces (12) and associated corner reinforcing bits (panels 9 and 11 and 13)) <- all panel numbers recalled from memory... I think that's them
