Help with amps/volts/watts/sepakers. (Leland's Article)
Re: Help with amps/volts/watts/sepakers. (Leland's Article)
#31 Post by Bruce Weldy »
TheCesar wrote:So let me tell you what I have and tell me how you would power it up:
Behringer EP2500Stero
•1 kHz
•8ohm -500W per/Chan
•4ohm- 750W per/Chan
•2ohm-1200w per/Chan
Bridge mode
•1 kHz
•8ohm-1300w
•4ohm-2400w
2 Sub cabs
1 Black widow peavey 1801 on each cab
•8 Ohms
•1400 W Peak, 700 W Program, 350 W Continuous
Put one sub on each side of the amp and call it a day until you build some new subs. They can actually take a little more probably - but why risk it?
