Page 3 of 4
				Re: OmniTop 12 and Tuba 30
				Posted: Tue Feb 15, 2011 7:04 pm
				digi128pci wrote:Is it ok to use a lager dowel ?
I prefer Pilsner.
18mm is OK. 15mm is better,
				Posted: Tue Feb 15, 2011 9:43 pm
				by netwerks
				Bill Fitzmaurice wrote:digi128pci wrote:Is it ok to use a lager dowel ?
I prefer Pilsner.
				Posted: Wed Feb 16, 2011 5:39 am
				by digi128pci
I prefer Pilsner.
Guess im going to look for 5/8 pvc pipe
				Posted: Wed Feb 16, 2011 8:09 am
				by Chris_Allen
				Bill Fitzmaurice wrote:18mm is OK. 15mm is better,
Bill, you do realise you just quoted something in Metric!
On a related question, does it make any difference if the finish is smooth or rough?
				Posted: Wed Feb 16, 2011 8:17 am
				Chris_Allen wrote:Bill Fitzmaurice wrote:18mm is OK. 15mm is better,
I said I don't care for it. Never said I couldn't use it.
Only above 40kHz.
				Posted: Tue Mar 15, 2011 4:37 pm
				by digi128pci
				Hello again!
Im building my second OT12 at the moment, but i want to add a grill! I saw the wooden part used to mount the grills in the plans!
But i can't figure out how to best mount the grill and place the 4(?) wooden parts that need to be glued to the reflectors of the OT12.
Also the plans state to add a tick weatherstrip to the melded array, but there are no straight edges where i can tape it to or should i put theme on the grill?
Does anyone have some pictures to make me better understand how to add the grill?
Soon i will start the build of the two T30 subs. But i am wondering if i should go for the 24" or 27" T30?
The drivers i will use are the Delta 12LFA, i had theme laying around so why not use theme.
The tops are 2 OT112 with a DELTALITE 2512 II driver and melded array.
I think i would prefer the 24" cause they are more compact to move around and fit our new car.
I don't know if there is much difference between the 24" en 27" version but i don't want my tops to overpower my subs.
Just wanted to try this
				Posted: Tue Mar 15, 2011 7:46 pm
				by doncolga
				Hey man,
Really nice looking build!  You should be proud if that's your first.  What are you doing your cuts with...they look really clean.
Donny
				Posted: Tue Mar 15, 2011 10:44 pm
				by digi128pci
				Thank you!
It is my very first build
Im using an new tool i bought for the job!
It is very useful, light easy to use, you can do circles with a special tool!, ... The only drawback you cant do angles so for that i use a circular saw, after that i sand theme a bit.
				Posted: Wed Mar 16, 2011 11:04 am
				by DJPhatman
				digi128pci wrote:Soon i will start the build of the two T30 subs. But i am wondering if i should go for the 24" or 27" T30?
Do yourself a favor and build T39s. They use the same drivers as the T30 but get louder above 35Hz.
Since you play electronic music, you want the higher sensitivity in the sub.
				Posted: Wed Mar 16, 2011 5:20 pm
				by digi128pci
				Hello,
You made me rethink the subbs i planning to build. But i already bought the plans for the T30.
Maybe the T39 is easier to move around and to transport. Can you V couple theme too?
Is the T39 that much better than the T30?
Should i go 16" 20" or 24"?
				Posted: Wed Mar 16, 2011 5:36 pm
				digi128pci wrote:Hello,
Probably depends on what you are using them for.  If you are good getting down to 40-45hz and don't need to go lower - then by all means, build the T39s.  Much easier to move at 19 inches deep and louder.  Build 'em with the 3012LF and you'll be blown away.  Yes, you can v-plate 'em.  Make as wide as you can handle.
And hey....what's another 15 bucks at this point, right?
				Posted: Wed Mar 16, 2011 6:27 pm
				by digi128pci
				You are right! ill go for the T39
But i have the DELTA 12LFA drivers laying around so is it oké to use theme?
				Posted: Wed Mar 16, 2011 8:13 pm
				digi128pci wrote:You are right! ill go for the T39
they are on the approved list.......use 'em.
				Posted: Thu Mar 17, 2011 3:14 pm
				by el_ingeniero
				Bruce Weldy wrote:digi128pci wrote:You are right! ill go for the T39
But will only go half as loud.
				Posted: Fri Mar 18, 2011 8:54 am
				by digi128pci
				So you mean 3 dB less?
