Titan 39 20" Wide 12" Sub Build (Completed)
Re: Titan 39 20" Wide 12" Sub Build
#31 Post by LelandCrooks »
Rendog, send me an email. All the titan kits come with 1 3/4 bolts. If yours are an inch, I'll take care of it. Although I don't know where they came from, 1 1/4 and 1 3/4 are all I stock.
Recex are hard to drive in a titan cab, unless you have
and still not very easy.
Plus I think the subs should have bolts.
RENDOG
#32 Post by RENDOG »
Thanks Phatman...."these should have been in your kit"
The box from Leland was in a room away from the garage, so I walked in and grabbed a bag with hurricanes and the shorter bolts in it. I didn't see the other bag with the longer bolts and hurricanes. I'm going to assume that the shorter ones are for the access panel.
Thanks Leland...yes it was in your kit lol :oops:
I have that tool, thanks. I purchased it at Sears.
Here's a pic of the shorter and longer bolts. Where do I place the washers for the spacer and baffle step?
SeisTres
#33 Post by SeisTres »
I too was wondering why you were thinking about using the 1" and the wood screws if you had ordered the kit :confused:
But problem solved, now get back to building :)
#34 Post by LelandCrooks »
The short ones are access panel screws. There should have been a screw chart (which I really need to add some pictures to) in your box describing which screws are used where. All the washers go on the long bolts.
RENDOG
#35 Post by RENDOG »
LelandCrooks wrote:All the washers go on the long bolts.
So washers go on the back of the woofer?
What size drill bit for the Hurricanes?
#36 Post by LelandCrooks »
RENDOG
#37 Post by RENDOG »
Thanks Leland....that helped big time.
I cut the spacer and clamped it down against the baffle and drilled my holes. I then did what you showed in the pics from that other thread regarding the hurricanes.
Now i realize that i should have glued the spacer to the baffle first then drilled the holes?
#38 Post by Tom Smit »
...ahem<clears-his-throat>yes
RENDOG
#39 Post by RENDOG »
I'm learning....thanks.
#40 Post by Bill Fitzmaurice »
That is what the plans specify. :wall:
RENDOG
#41 Post by RENDOG »
I know Bill, totally my fault.
I placed the spacer on the panel, then used the long bolts and screwed them down a little. Next, I lifted the spacer up and put adhesive on the panel away from the bolts. Clamped that down and then let it dry and then used more adhesive on the ring. I made sure to keep adhesive away from the hurricanes.
Check out the clearance on this next panel, does it look right? It seems really close to the top cover opening but I triple checked the measurement on the side panel.
RENDOG
#42 Post by RENDOG »
More progress.
RENDOG
#43 Post by RENDOG »
More progress today (Tuesday Dec 28th)
#44 Post by Gregory East »
RENDOG wrote:Image
did you repair that chipout by the hole? Might be a bit much to ask of the gasket.
RENDOG
#45 Post by RENDOG »
Gregory East wrote:
RENDOG wrote:Image
Good Point....what do you recommend?
