exactly. I recently had to cut a hole in the chamber of one of my t48s (front mounted) because a hurricane nut that was heavily epoxied still spun.... patched it up and cant even tell it happened.
sine143 wrote:exactly. I recently had to cut a hole in the chamber of one of my t48s (front mounted) because a hurricane nut that was heavily epoxied still spun.... patched it up and cant even tell it happened.
Anyway, glad to hear you were able to effect a repair and it's not noticable. Did you use one of those newfangled oscillating blade tools to make the cut?
oooh.. 4 T48's cant wait to hear your impressions!miked wrote:sine143 wrote:exactly. I recently had to cut a hole in the chamber of one of my t48s (front mounted) because a hurricane nut that was heavily epoxied still spun.... patched it up and cant even tell it happened.Was that t-nut also screwed down, ala Harley's T-nut Trick? Asking b/c I'm about to start making sawdust on my 4, T48 build and plan on using Harley's trick. I.E. small screw wedged inbetween the t-nut prongs and epoxy over the whole thing.
Keryn O'Shea
IMHO, the invert looks excellent! If you dont think so now, and then fit grilles, l think you will then..
It was a hurricane nut, and I didnt have access to a drill press, so I was unable to screw a hole to anchor it with a screw. It was installed with plenty of epoxy and drawn into the hole with a bolt, and left for 24 hours, so I was very upset when it spun (8 hours before a major event). I drilled some 3/4 inch holes in the top with a spade bit and took it out with a jigsaw. installed flanges on the hole with 1/4 inch ply, put the original piece back in with A LOT of PL, and filled the 3/4 inch holes with pl. chiseled it down after the show, sanded and used plasticwood. duratex and it was gone.
Just use a hand drill. Take a piece of scrap, drill a hole big enough for the nut to sit in. Drill a hole in the lip with a hand drill. It's stable and works fine.sine143 wrote: It was a hurricane nut, and I didnt have access to a drill press, so I was unable to screw a hole to anchor it with a screw.
Wow, 8 hours before a show...you pulled if off though!sine143 wrote:miked wrote:sine143 wrote:exactly. I recently had to cut a hole in the chamber of one of my t48s (front mounted) because a hurricane nut that was heavily epoxied still spun.... patched it up and cant even tell it happened.Was that t-nut also screwed down, ala Harley's T-nut Trick? Asking b/c I'm about to start making sawdust on my 4, T48 build and plan on using Harley's trick. I.E. small screw wedged inbetween the t-nut prongs and epoxy over the whole thing.
I tried hurricane nuts ONCE. It was the most miserable experience of my speaker building life. 4 of the 8 spun on me as I was torquing down the bolts for the first time. This was a long time ago, so there was no "Harley Trick." I've haven't used anything but t-nuts for 15+ years now. I've never done the Harley Trick before, but I've never built a sub as complicted as a Titan before either. Last thing I want is watching weeks' worth of work go down the drain b/c of a stupid 5-cent t-nut.
Bruce Weldy wrote:Just use a hand drill. Take a piece of scrap, drill a hole big enough for the nut to sit in. Drill a hole in the lip with a hand drill. It's stable and works fine.sine143 wrote: It was a hurricane nut, and I didnt have access to a drill press, so I was unable to screw a hole to anchor it with a screw.
sorry for taking your thread on a detour hifibob! back to regular programming after this.
I broke all my small drillbits in haste during the build process lol.
Bob: Another positive vote for the reverse-curve. I think it looks great and will look even better once you paint the cabs and get the grill on there.
Titanium Hand
Every single time I check on your thread I find myself pretty much drooling! Whether its of your endless cache of quality tools, or your prowess in building with them, maybe its just the sheer magnitude of your rapidly forming fleet of BFM Big Boys.
All good stuff HifiBob
+3 Inverted curve on the DR's
- Chris_Allen
You have absolutely ruined those cabs. You have no option but to start again. I'll send you a disposal address in the UK for you to get rid of them.
What's this club gonna be called and when will it be open and where will be exactly got a buddy going out to Boston in middle of August and he might check it out
Hifi says its a dtenative mid sept opening. Hopefully he'll chime in with a name
lol.. no biggy sine, I can tell ya though I had a nightmare last night that all my T-nuts stripped!sine143 wrote:Bruce Weldy wrote:Just use a hand drill. Take a piece of scrap, drill a hole big enough for the nut to sit in. Drill a hole in the lip with a hand drill. It's stable and works fine.sine143 wrote: It was a hurricane nut, and I didnt have access to a drill press, so I was unable to screw a hole to anchor it with a screw.
It is starting to grow on me too.. I think finished it will look pretty bad ass!miked wrote:Bob: Another positive vote for the reverse-curve. I think it looks great and will look even better once you paint the cabs and get the grill on there.
Thanks Titanium! I do love this stuff and I cant wait to be done building the nightclub so I can start building other designs! I'm dying to give a T48 a whirl..Drooooool!
haha I got nervous when I started to read this, I though I messed something up until I kept reading.. They're in the mail my friend!You have absolutely ruined those cabs. You have no option but to start again. I'll send you a disposal address in the UK for you to get rid of them.
mbraver the first one will be open mid sept. and that's located in Providence Rhode Island and its called Therapy, then I'm shooting for a February opening in Boston if all goes well..What's this club gonna be called and when will it be open and where will be exactly got a buddy going out to Boston in middle of August and he might check it out
