Hello! New guy here. (long read)
Re: Hello! New guy here. (long read)
#16 Post by Tom Smit »
jcmbowman wrote:Rune a sine wave test tone at a frequency within the passband for the sub, and measure using an RMS multi-meter -without- the speakers hooked up.
What does this mean? I haven't learned it yet.
Thanks.
#17 Post by DJPhatman »
Put a RMS AC voltmeter across the outputs of the amp, with no speakers hooked to it. For subs, run a 40Hz test tone into the amp and read the voltage. Set your limiter to max at the voltage limit desired.
In a car, set the head close to max volume with the 40Hz test tone playing (you should not hear it through the other speakers) then set the amp gain to your desired limit. Don't use the max volume, as this will most likely distort. I set mine with the sub hooked up, so it doesn't get stupidly loud. I like the good bass, but I like what's left of my hearing more.
#18 Post by Tom Smit »
Thanks.
Does "pass band" mean the frequency range that the sub works in?
jcmbowman
#19 Post by jcmbowman »
tammojsmit wrote:Thanks.
yes.
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
#20 Post by Tom Smit »
Okay, thanks!
#21 Post by Seth »
jcmbowman wrote:As far as the voltage... the MCM driver is rated for 120 watts RMS, so with a pair of those in an autotuba you'd want to be able to feed 240 watts into 6 ohms.
Following the formula: Watts x Ohms = Volts^2
You get the following: 240 x 6 = 1440 = volts^2
So Volts = SQRT(1440) = ~38 Volts.
Limit to 35 volts off your amp just to be safe, and you're all set.
I sure hope that the horn really does add impedance. If I do the math for 35 volts into 2 ohms, which is essentially what it'll be wired for, I get over 600 watts RMS! Don't think the speakers would last too long with that much juice.
Anyone have any links to some information about how/why a horn adds impedance? I assume it has to do with the mass and velocity of the air in the horn acting against the drivers cone which somehow produces added electrical resistance in the coil, but it'd be nice to read and learn about it from a more reliable source than my assumptions.
Rickisan
#22 Post by Rickisan »
Here is the educational materials area of the forum http://billfitzmaurice.net/phpBB3/viewforum.php?f=18
I would try searching on horn driver/cabinet impedance or similar. Good Luck!
2-Jack 10
2-Wedgehorn 8
1-Auto Tuba
