What does this mean? I haven't learned it yet.jcmbowman wrote:Rune a sine wave test tone at a frequency within the passband for the sub, and measure using an RMS multi-meter -without- the speakers hooked up.
Thanks.
yes.tammojsmit wrote:Thanks.
Does "pass band" mean the frequency range that the sub works in?
I sure hope that the horn really does add impedance. If I do the math for 35 volts into 2 ohms, which is essentially what it'll be wired for, I get over 600 watts RMS! Don't think the speakers would last too long with that much juice.jcmbowman wrote:As far as the voltage... the MCM driver is rated for 120 watts RMS, so with a pair of those in an autotuba you'd want to be able to feed 240 watts into 6 ohms.
Following the formula: Watts x Ohms = Volts^2
You get the following: 240 x 6 = 1440 = volts^2
So Volts = SQRT(1440) = ~38 Volts.
Limit to 35 volts off your amp just to be safe, and you're all set.
