Recessed Strap Handle for T39S
SoundInMotionDJ
Re: Recessed Strap Handle for T39S
#16 Post by SoundInMotionDJ »
novasak wrote:Hi,
I'd like to include this recessed handle on my latest T39s. Where is the typical balance point on the back of the the box? 3/4 up from the bottom? 2/3?
Because of differences in construction details, it is better if you determine the balance point on your cabs as they are built. In my case, I was able to check two other fully completed cabinets to determine the balance point.
If you still have the second side off, then place the woofer on the baffle, attach the second side with a couple of screws (two or three will do), and use a 1/2" x 1/2" piece of scrap to find the center of gravity of the box. Center the handle on that point.
The hole for the handle recess can be cut with a jigsaw with the back installed in the box.
novasak wrote:and does this interfere with the bracing at all?
No...but I accounted for that in the design. You can see the bracing in this pic. I added a couple of scraps of wood to hold a brace to the handle backer. PL and a couple of 1/4" staples held everything in place. All of the braces are 1/4", and there are dados for the braces on all panels that have them.
--Stan Graves
novasak
#17 Post by novasak »
yes! Pictures!!! This'll help me out tons.
Thanks a lot.
