Simple circle jig
bgavin
#17 Post by bgavin »
That is a $10 savings over the Lowes price.
#18 Post by LelandCrooks »
bgavin wrote:That is a $10 savings over the Lowes price.
Another addition to the site. Hadn't considered router bits.
bgavin
#19 Post by bgavin »
The up-spiral cutting bit is one to stock, for sure. I'll buy one from you.
See if you can find a tapered cutting bit, for the tapered speaker holes in the plans. 45-degrees seems to be too steep an angle. Perhaps 60 degrees would be better. The intent is having enough meat on the bottom side of the baffle for the T-nut flange.
SoundInMotionDJ
#20 Post by SoundInMotionDJ »
bgavin wrote:The up-spiral cutting bit is one to stock, for sure. I'll buy one from you.
Use a 14 deg dovetail bit, and cut from the side where the speaker will mount.
http://routerbitworld.com/Freud_22_104_ ... 22-104.htm
--Stan Graves
10 T39S + 10 DR200 + 1 T48
bgavin
#21 Post by bgavin »
Actually, you have to cut from the side opposite where the speaker mounts. The smaller diameter of the baffle cutout hole is where the T-nut mounts, which is on the side opposite the speaker.
I'd like to find a chamfer router bit that is wider, closer to the chuck. Then I wouldn't have to flip the board over.
Something like this
Or this
SoundInMotionDJ
#22 Post by SoundInMotionDJ »
bgavin wrote:Actually, you have to cut from the side opposite where the speaker mounts.
:oops:
You're correct. That's what I get for typing without having the plans and the bit in front of me...
--Stan Graves
#23 Post by LelandCrooks »
Dovetail bit?
http://routerbitworld.com/Freud_22_122_ ... 22-122.htm
Mount your own bearing on the top.
bgavin
#24 Post by bgavin »
Nope. It has to be a Chamfer bit. Wider at the chuck side, narrow at the tip. I want to use it with a Jasper Jig to cut tapered baffle cutouts with the smaller diameter on the T-nut side.
I've been using a 45-degree bit, but this is too much. A 60-degree bit would be much better. It doesn't remove as much material.
Link to Hi-Res Photo
The link will show exactly what I mean. This is for the MCM 55-2421 driver that I used in my experimental HT sub. Note how much wood is available on the bottom side for the T-nuts.
#25 Post by LelandCrooks »
http://www.freudtools.com/p-151-chamfer-bits.aspx
I have easy access to the 15, 25, and 45. 40-102, 40-100, 40-104 and 40-106. :?:
#26 Post by DJPhatman »
I have the 45 1" with the bearing...I use a circle tempate underneath for the bearing to ride on...can't post pics anymore, digicam broke :x
bgavin
#27 Post by bgavin »
I think the 25-degree bit would be the ticket. It is halfway between the 45, which is too steep, and vertical.
DaveK
#28 Post by DaveK »
I needed to cut some 15" driver holes and this is the solution I came up with. Use a straight router bit and a circle jig to cut a 13.5" hole. Then widen the top of the hole to 14" using a 45 degree chamfer bit with a bearing and set at 1/4" depth. I didn't need the circle jig for the chamfer because the bearing rode on the inside of the hole.
