Duratex: spray vs. roller
Tim A
#16 Post by Tim A »
That's plenty. Mine is rated 5.6 CFM @ 90 with a 22 gal tank and I never have to wait for it to recover.
MYork
#17 Post by MYork »
Thanks! MY
fender3x
#18 Post by fender3x »
Can it be done with a small compressor...a pancake or 2-6 gal?
#19 Post by LelandCrooks »
Yes. You need a valve on the gun, or the compressor will never catch up.
DaveK
#20 Post by DaveK »
I finally got set up to spray and I'm very pleased with the results. Roller and paintbrush just don't come out right for me, but spraying gives a nice texture and is a lot faster, too.
I used the Harbor Freight hopper gun and a Porter-Cable 6 gal, 0.8 hp pancake compressor. The compressor was rated for 3.7 cfm @ 40 psi, while the sprayer wants 4-6 cfm @ 50-70 psi, but it worked fine. It could spray continuously and was throwing Duratex 3-4 feet. I was using roller formula and one gallon did a T39 and 2 Wedgehorns.
fender3x
#21 Post by fender3x »
Good to know. I have a hopper gun and a friend has offered to let me use his compressor. I was considering doing the roller anyway....just because I have done it before and it came out pretty well... May push to borrow the compress tho after hearing your report.
bgavin
#22 Post by bgavin »
I picked up a decent hopper gun at Lowes to use with my compressor. I'm just leery as hell about spraying... don't need a big mess.
wannabe
#23 Post by wannabe »
You can use speaker stands, lighting stands PVC or extra wood to build a little spray booth and just hang news paper or old sheets to catch the over spray.
#24 Post by Bill Fitzmaurice »
wannabe wrote:You can use speaker stands, lighting stands PVC or extra wood to build a little spray booth and just hang news paper or old sheets to catch the over spray.
I just let it blow into my neighbors yard. :lol:
bjhueni
#25 Post by bjhueni »
And across his driveway where his new white Lexus is parked...
Hehehehehehehehe.
One hit wonder?
I think one hit would be wonderful!
DaveK
#26 Post by DaveK »
bgavin wrote:I'm just leery as hell about spraying... don't need a big mess.
Try the middle of your lawn on a windless day. All the overspray disappears the next time you cut the grass :-)
