Page 2 of 3
Re: A pair of SLAs... Perhaps..
Posted: Sun Jul 24, 2022 2:05 am
by JensToft91
Bill Fitzmaurice wrote: ↑Sat Jul 23, 2022 3:05 pm
Their data is flawed, because modeling programs are only accurate up to about 200Hz. They also show results if mounted in a wall baffle, not enclosures of equal size. Worse, they measure one at 2.83v, one at 4.0 v. I don't know what that's all about, but it accounts for a 3dB difference.
Thanks again Bill.
I'll probably start the saw tomorrow.
Posted: Wed Jul 27, 2022 1:55 am
by JensToft91
Ah damn. I thought the "1/2 inch voice coil" was the dome size. My tweeter is 1 inch. So pretty far from the plans, I hope it doesn't screw things up.
How would you mount the 4PF-8? I'm thinking about front-mouting then because it's easier - and want to make some grills for them anyway.
Does it make a difference?
Posted: Wed Jul 27, 2022 5:13 am
by JensToft91
SLA is a bit simpler to build than the tubas.
Boxes dryfitted
Posted: Wed Jul 27, 2022 6:55 am
by JensToft91
Drivers has arrived
Posted: Wed Jul 27, 2022 9:59 am
by Seth
Dang Jens, you're moving right along on this venture
I'm not sure the dome size will or won't negatively effect the sonic quality of your build. But, I would think if the frame size is still 2½" or less, you should be fine. We'll see what Bill has to say about the suitability of 1" tweeters instead of the recommended 3/8 to 1/2 inch variant. I'm curious too.
Posted: Wed Jul 27, 2022 10:13 am
1" tweeters won't have as wide dispersion as smaller units. The reason to use 1" is when they're crossed over fairly low, which you do with larger midbasses because they have narrower dispersion in their upper end than smaller midbasses. Other than with subs the reason to use a particular size driver is output capability versus dispersion, which is always a compromise.
Posted: Wed Jul 27, 2022 11:54 am
by JensToft91
Makes sense. Hope it'll work out!
Posted: Fri Jul 29, 2022 5:45 am
by JensToft91
Read the instructions. Twice. And then one more time.
Then check the drivers you're buying. Then check them again.
I'll probably be better at cutting them as I go along. First one is not pretty. I'll smooth it out with some acrylic filler. Wood filler, perhaps?
Posted: Fri Jul 29, 2022 6:36 am
by JensToft91
Not so pretty. But it'll work. Next challenge is to seal it properly.
Posted: Fri Jul 29, 2022 8:44 am
by JensToft91
Posted: Fri Jul 29, 2022 10:44 am
by Seth
Good job Jens. I'm not sure my mind would have come up with that solution on its own. Very creative
Is it your intention to use them for the outdoor deal? Or are you still planning on using the boominator for that?
Posted: Fri Jul 29, 2022 12:29 pm
by JensToft91
Seth wrote: ↑Fri Jul 29, 2022 10:44 am
Thank you.
I'm thinking the boominator, but it could be fun with these.
I really underestimated all the wiring and hole cutting. A moment of silence for those of you, who has build til TLAH and SLA centers.
And then all the modifications I have to do. Failing to plan is planning to fail, right?
Posted: Fri Jul 29, 2022 2:22 pm
by Rich4349
I thought the idea was to cut all of the interior, adjoining edges flat?
Posted: Sat Jul 30, 2022 3:04 pm
by JensToft91
Sorry guys. I won't be finishing the project anyway. Thanks for all your answers.
I'll say goodbye (again!) - and hopefully this time, I'll be able to stay off the internet and speaker addiction for good.
I actually just took a drill trough all "DIY" components I have lying around. Not the ones I'm actually using ofcourse.. It's really not healthy for me - time to focus on the family
Bye!
Posted: Sat Jul 30, 2022 10:20 pm
Oh man! I hope that everything is alright.
