Page 2 of 2
Re: HT setup using T24
Posted: Sat Jul 16, 2022 3:27 pm
by T_Gowan
Yes I have been through this menu. The only speaker that can have cross over adjusted are the main center and surround. The sub only level and distance
Posted: Sun Jul 17, 2022 9:40 am
by T_Gowan
Who has experience with the mini dsp. I see a main board, a input output connector board and an optional interface board to allow more controls via PC . What is the least I need to just do hi and low pass
Posted: Sun Jul 17, 2022 10:41 am
You can't use it with your receiver to high pass. That would require the ability to insert it between the pre-amps and power amps.
Posted: Sun Jul 17, 2022 12:06 pm
by T_Gowan
I am using an external amp for the sub. The LRC and surround is being processed by the Sony. I just need to process the sub
Posted: Sun Jul 17, 2022 1:38 pm
You said 'The only speaker that can have cross over adjusted are the main center and surround', with no mention of the L/R. Whatever. For both low passing and EQ I'd use this:
https://www.parts-express.com/Dayton-Au ... er-230-520
It's not user friendly, because the instructions are crap. But I found other subs that use the same control app and their instructions are OK.
Posted: Sun Jul 17, 2022 2:17 pm
by Seth
Punctuation to the rescue!
T_Gowan wrote: ↑Sat Jul 16, 2022 3:27 pm
Yes
, I have been through this menu. The only speaker
s that can have cross over adjusted are the main
, center
, and surround...
LOL
Posted: Sun Jul 17, 2022 2:26 pm
Punctuation matters.
Posted: Sun Jul 17, 2022 8:18 pm
by jimbo7
Let's eat kids!
Let's eat, kids!
Posted: Mon Jul 18, 2022 6:56 am
by T_Gowan
For an old guy I'm falling into bad habits.
Posted: Mon Jul 25, 2022 6:44 am
by T_Gowan
Order the Parts Express Dayton Audio device, A little more than I hoped to spend but it should do the trick. 150 Canadian with tax and shipping. The shipping was as much as the unit.
Posted: Thu Aug 11, 2022 7:19 am
by T_Gowan
Got the unit and the learning curve is a bit steep due to crappy instructions. But it does the trick.
Posted: Thu Aug 11, 2022 8:27 am
by T_Gowan
Works well with iPad but android phone won't seem to connect.
Posted: Thu Aug 11, 2022 8:29 am
by T_Gowan
https://hometheaterhifi.com/reviews/aud ... ontroller/
This review and instructions are quite good compared to the instructions with the unit.
Posted: Thu Aug 11, 2022 8:47 am
I ended up using the instructions for the Earthquake Sound MiniMe DSP, which uses the same software.
