3015LF on JL150
joblow88
Re: 3015LF on JL150
#16 Post by joblow88 »
Seth wrote: Fri Apr 22, 2022 1:49 pm
joblow88 wrote: Fri Apr 22, 2022 10:50 am We have been using a pair of preamp 12'' from jbl that we borrow from our frind for the longest time. now we upgraded to a pair of mrx525 from jbl. amp wise i got 3 qsc rmx4050 and an other qsc 1500w
Tell me a little about your opinion of the performance of the MRX525's. Do they do what you want them to do, are they lacking anything? Other than reducing pack space, what improvements would you like to achieve as an upgrade to the system?
Personaly i tough it was the bomb when we received them. Now i know that i could make something better and i have the grant to do it. Where the idea of making this set.
Re: 3015LF on JL150
#17 Post by Seth »
joblow88 wrote: Fri Apr 22, 2022 7:24 pm
Other than reducing pack space, what specific improvements you would like to achieve? What aspect of the listening or user/operating experience do you intend on making better?
joblow88
Re: 3015LF on JL150
#18 Post by joblow88 »
Well the mrx are not mine they are my roommate and im moving out so i want to make a setup for myself
joblow88
Re: 3015LF on JL150
#19 Post by joblow88 »
joblow88 wrote: Fri Apr 22, 2022 9:51 pm Well the mrx are not mine they are my roommate and im moving out so i want to make a portable setup for myself
Re: 3015LF on JL150
#20 Post by Seth »
joblow88 wrote: Fri Apr 22, 2022 9:51 pm Well the mrx are not mine they are my roommate and im moving out so i want to make a setup for myself
Are all the amps his as well? Are you starting from scratch?
joblow88
Re: 3015LF on JL150
#21 Post by joblow88 »
No all the amps are mine :D i lend them one untill they can pay for it
Re: 3015LF on JL150
#22 Post by Bill Fitzmaurice »
For the size crowds you do the best mains would be SLA Pro, Simplexx 12, DR200, Jack 10 or 12, OTop 8 or 12, and DR200. Anything larger isn't going to be better, it's just going to be larger. If you're going to have a strong low end you don't get it with bigger mains, you get it with subs.
Re: 3015LF on JL150
#23 Post by Seth »
joblow88 wrote: Fri Apr 22, 2022 11:56 pm No all the amps are mine :D i lend them one untill they can pay for it
I just reread your original post and realized you hadn't actually asked for a cab recommendation. Is your mind made up on the Jack15 or are you open to recommendations?
joblow88
Re: 3015LF on JL150
#24 Post by joblow88 »
Im open for recommendations. I just realised that the otop 12 would fit in my trunk and then i could put a sub on the back seat... Maybe a pair of t24, one t30 one t39 or even a silm t48. My favorite sound system is mtl bassix wich is 12 stack of t60 but that is way too big. But i like the idea of having one day 8 or 12 t30 v plated together. Can you stack sub that are not the same width but same driver?
joblow88
Re: 3015LF on JL150
#25 Post by joblow88 »
Just ordered one 3015lf for a t48 that's going on the back seat ant a pair of 2512 for a set of otop12 line aray so there's room for improvement every where. :hyper:
Re: 3015LF on JL150
#26 Post by Tom Smit »
joblow88 wrote: Sat Apr 23, 2022 2:02 pmBut i like the idea of having one day 8 or 12 t30 v plated together. Can you stack sub that are not the same width but same driver?
Yes, absolutely! :P
Re: 3015LF on JL150
#27 Post by Seth »
joblow88 wrote: Sat Apr 23, 2022 10:30 pm Just ordered one 3015lf for a t48 that's going on the back seat ant a pair of 2512 for a set of otop12 line aray so there's room for improvement every where. :hyper:
:thumbsup: Very wise choices. :clap:
Re: 3015LF on JL150
#28 Post by Seth »
Start shopping for a dbx Driverack. Considered mandatory gear for running horn loaded subs. Or any other signal processor that has adjustable Brick Wall Limiters... Behringer DCX2496, Ashly Protea, etc...
Unfortunately, limiters that are built into some amps are typically not effective brick wall limiters. :(
joblow88
Re: 3015LF on JL150
#29 Post by joblow88 »
already scored a ULTRADRIVE PRO DCX2496 for 300cad brand new. Should the job...
joblow88
Re: 3015LF on JL150
#30 Post by joblow88 »
ill not start the built until mid august because im working some 5000km from home for the summer. ill make a build post when i start
