Personaly i tough it was the bomb when we received them. Now i know that i could make something better and i have the grant to do it. Where the idea of making this set.
3015LF on JL150
Re: 3015LF on JL150
Re: 3015LF on JL150
Other than reducing pack space, what specific improvements you would like to achieve? What aspect of the listening or user/operating experience do you intend on making better?joblow88 wrote: ↑Fri Apr 22, 2022 7:24 pmPersonaly i tough it was the bomb when we received them. Now i know that i could make something better and i have the grant to do it. Where the idea of making this set.
Re: 3015LF on JL150
Well the mrx are not mine they are my roommate and im moving out so i want to make a setup for myself
Re: 3015LF on JL150
Are all the amps his as well? Are you starting from scratch?
Re: 3015LF on JL150
No all the amps are mine
i lend them one untill they can pay for it
Re: 3015LF on JL150
For the size crowds you do the best mains would be SLA Pro, Simplexx 12, DR200, Jack 10 or 12, OTop 8 or 12, and DR200. Anything larger isn't going to be better, it's just going to be larger. If you're going to have a strong low end you don't get it with bigger mains, you get it with subs.
Re: 3015LF on JL150
I just reread your original post and realized you hadn't actually asked for a cab recommendation. Is your mind made up on the Jack15 or are you open to recommendations?
Re: 3015LF on JL150
Im open for recommendations. I just realised that the otop 12 would fit in my trunk and then i could put a sub on the back seat... Maybe a pair of t24, one t30 one t39 or even a silm t48. My favorite sound system is mtl bassix wich is 12 stack of t60 but that is way too big. But i like the idea of having one day 8 or 12 t30 v plated together. Can you stack sub that are not the same width but same driver?
Re: 3015LF on JL150
Just ordered one 3015lf for a t48 that's going on the back seat ant a pair of 2512 for a set of otop12 line aray so there's room for improvement every where.
Re: 3015LF on JL150
Re: 3015LF on JL150
Start shopping for a dbx Driverack. Considered mandatory gear for running horn loaded subs. Or any other signal processor that has adjustable Brick Wall Limiters... Behringer DCX2496, Ashly Protea, etc...
Unfortunately, limiters that are built into some amps are typically not effective brick wall limiters.
Re: 3015LF on JL150
already scored a ULTRADRIVE PRO DCX2496 for 300cad brand new. Should the job...
Re: 3015LF on JL150
ill not start the built until mid august because im working some 5000km from home for the summer. ill make a build post when i start
